Front Coil Spring Installation Help
That isn't going to fix your problem of not being able to compress the spring, but I think it makes the whole process more manageable.
Got any pics of what you're doing? Are you extending the compressor fully before hooking it onto the coils?
2. Place the bottom fork or equitant part of the compressor kit as low as u can with out the fork binding against the bottom a-arm once installed.
3. compress the spring
4. Install the top inside (car side) edge coil of the spring in the correct position in the seat. The spring will not be straight with the bottom a-arm, that's ok.
5. Position the inside edge of the bottom coil as close to the back of the bottom seat as possible. It will not line up but do the best you can.
6. Next jack up the bottom a-arm as close to the spindle as u can to get the most leverage.
7. While jacking it up keep pressure on the spring to prevent the top coil from coming out of the seat.
8. Jack it up enough so that the spring can still be moved (using a rubber mallet) and high enough to compress the spring.
9. Hit the spring with a mallet wile slowing jacking up the spring to find the point described in step 8. Removal of the bump stop may be necessary.
10. The spring should then pop into place, if not you need to move the hooks or fork up or down, or reposition the starting placement of the top and bottom coil prior to jacking/hitting.
11. If the bottom coil moves into place but the top pops outward (away from the car), slightly lower the a-arm and tap the spring while jacking it back up
Rick B.
only way to do it
