MSD and battery drain..?
Old Jan 15, 2006 | 10:29 AM
carbster09's Avatar
carbster09
Default MSD and battery drain..?
Hi,
I just fitted, or rather had the shop fit a new MSD to my LS-5's stock, recurved system. Now I have a serious battery drain. To the point that I am not wanting to drive the car very far.
SO .. I have ordered a battery dsconnect but this is not fixing the problem, just a band-aid. Has anyone had this with MSD before? Can I have a bad box? I heard that their quality is not as good as it used to be.
carbster09
Old Jan 15, 2006 | 11:20 AM
73 LS-4's Avatar
73 LS-4
Most of the aftermarket ignition boxes normally come with a bypass harness to take the box out of the igntion system loop. I don't remember if the MSD systems did or not but I know the Mallory units do. Try bypassing the unit and see if the drain goes away.
Pat Kunz
Old Jan 15, 2006 | 11:46 AM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
I put an MSD 6AL on the 65 last summer. I have had zero problems. I'd bet they have it hooked up wrong. Go to the MSD site http://www.msdignition.com/1ignitions.htm select on your ignition box. The installation instructions are there on the left.
Old Jan 16, 2006 | 03:31 AM
wnjlt1's Avatar
wnjlt1
Looking @ the wire layout my guess would be that they could have hooked the smaller gauge red wire to "hot" all the time source instead of the ignition key source. Trace the red wire up to where they tapped in. With the ignition off, use a test light to see if your getting power through that wire. You should not be. Good Luck!
Old Jan 16, 2006 | 08:17 AM
rastadr's Avatar
rastadr
b4 you go looking for a problem check the output of your alternator. msd boxs pull alot of current to produce the spark they do. it could be that b4 your alternator was doing the job but now too much is going to the box and not the bat.
Old Jan 16, 2006 | 11:45 AM
gerry72's Avatar
gerry72
The shop that did the install screwed something else up. It's not the MSD box. The MSD doesn't need to be hooked to a keyed power source since once the cap it charged, the box pulls no more juice which is why it's normally connected to a constant hot. Moving the power source will not solve your problem. If you want to test this theory, just do a simple test with a DVOM between the box and the power souce. If it's the problem, it will show an amp draw.
To MSD and battery drain..?
