My engine just dies
Old Jan 15, 2006 | 09:50 PM
Bangkok Dean's Avatar
Bangkok Dean
Default My engine just dies
I am having many problems with my Summit distributor, when I had 800 miles on the engine the module gave up on me then 100 miles later the condenser gave up. Now 50 miles more it is still giving me problems. For some reason the problem starts when it gets hot driving down the highway tacking just over 2200 rpm,s the tack starts bouncing. Then when I stop the car the engine idles ok at first then is shouts off like there is some sort of short? The car starts right up but this problem continues until the car has cooled down, then it is ok again?
Old Jan 15, 2006 | 10:24 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
strange..... i wonder if you have a high resistance circuit some where that the resistance is increasing with temp and you have a voltage drop....how clean is the battery connection to the dist?
Old Jan 15, 2006 | 10:31 PM
DR.Jay's Avatar
DR.Jay
Is the coil getting very hot? If the coil over heats it's internal resistance climbs, and you lose spark. The ignition module can cause the same symptoms. Especially the jumping tach. When you replaced the ignition module did you coat it with the white grease on the back. If not it will fail in a very short time. Keep us updated on the outcome.
DR. Jay
Old Jan 15, 2006 | 10:50 PM
evalu8r's Avatar
evalu8r
DR. Jay
Old Jan 16, 2006 | 11:13 AM
UKPaul's Avatar
UKPaul
DR. Jay
I also agree! Good luck finding the problem, Dean.
Old Jan 16, 2006 | 11:30 AM
Bangkok Dean
Thanks guys I will check out the modual again.
To My engine just dies
