Tremec TKO-600 Installation Question....
Old Jan 16, 2006 | 03:26 PM
BlackRocket's Avatar
BlackRocket
Default Tremec TKO-600 Installation Question....
I'm currently in the process of doing a frame-off and having a custom tube frame built by SRIII motorsports. Keisler is running a sale on their 5-speeds for only $1,780!!! The kit with the modified tail housing is over $3,000
The question I have is that with a custom frame do I need the specialized transmission that Keisler makes or can I use a standard GM TKO-600???
Old Jan 16, 2006 | 03:52 PM
zwede's Avatar
zwede
You can run any Tremec TKO with the generic GM modifications (bolt pattern & input shaft). I used a regular GM TKO and it wasn't a big deal to fit it. The tail has a torque mount that you cut off (saw-z-all or cutting wheel). The shifter comes up the middle so I had to make the tunnel hole larger and cut/weld the shifter to go over to the left. I used the stock center console. That's about it. I had the drive shaft shortened at a 4x4 shop for $80 including a spicer U-joint.
Old Jan 16, 2006 | 03:57 PM
jamesx0's Avatar
jamesx0
1780? That isn't what I see on their website.
Old Jan 16, 2006 | 08:13 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
The $1780.00 is just for the unmodified gear box only. JamesxO
To Tremec TKO-600 Installation Question....
