Autometer Speedo and Tach
Old Aug 5, 2001 | 09:39 PM
Monty's Avatar
Monty
Default Autometer Speedo and Tach
I think it was Rolling Thunder who posted some images of his Autometer Speedo and Tach install. His looked very nice. I just finished mine today, here's a trial fit. I still need to tihhten the screws holding the housing in the dash. My other gauges are also matching Autometer Ultralights.
[Modified by Monty, 7:41 PM 8/5/2001]
Old Aug 5, 2001 | 09:47 PM
ScubaJKD's Avatar
ScubaJKD
Default Re: Autometer Speedo and Tach (Monty)
That looks awesome. Great job on a cool mod.
Old Aug 5, 2001 | 11:20 PM
INTIMIDATOR ZO6's Avatar
INTIMIDATOR ZO6
That looks very nice :cool: I see also that you mounted the gauges on a seperate piece of plastic good idea :cheers: Here's a pic of my gauges :seeya pic2 pic3 KENWOOD SPEAKER BOX for sounds KENWOOD 600 WATT AMP so I can listen to the music over the engine noise :D
Old Aug 6, 2001 | 09:26 AM
Monty's Avatar
Monty
Default Re: Autometer Speedo and Tach (Intimidator454)
Intimidator,
I had a machine shop make me a panel out of 3/16" aluminum plate, using the original bezel as an outer template. Then thye cut the 4 5/8" holes for the 5" speedo/tach. They couldn't cut the rectangular holes for the warning lights, but I've now found someone you can (CNC). I'll probably get it redone this winter when I'm not in a rush. If you want one for your gauges, I could just have two made at the same time.
Old Aug 6, 2001 | 11:43 AM
fauxrs's Avatar
fauxrs
I like it, but there is a reason.
I've done mucht eh same with mine. :cool:
Instructions on my web site at : http://www.corvetteforum.net/c3/fauxrs/gauge.htm
Old Aug 6, 2001 | 11:54 AM
Alwyn678's Avatar
Alwyn678
Default Re: Autometer Speedo and Tach (fauxrs)
Part of my favorite things on a corvette are the original gauges....Though U guys have don a fantastic Job with the changeover......I guess I am just a old skool purist :cheers:
Old Aug 9, 2001 | 11:07 AM
vettedan's Avatar
vettedan
I just finished installing my Autometer electronic speedo and Tach. very accerate. Uses Vss signal from tranny.
Dan
Old Aug 9, 2001 | 01:20 PM
Monty's Avatar
Monty
Default Re: Autometer Speedo and Tach (vettedan)
Yep, that was you Vettedan that I was thinking about. Once again, you did an excellent job on your install. Did you figure out your warning lights situation?
Old Aug 9, 2001 | 03:32 PM
vettedan's Avatar
vettedan
Default Re: Autometer Speedo and Tach (ScubaJKD)
Monty-Thanks for the complement. You did a mighty nice install on yours as well. It looks great. They’re much better looking than the factory gauges. I preferred the white gauges over the black, but I didn’t want to have to replace all the other gauges. I put the parking brake, turn signal and high beam indicators location on hold. I have to finish some suspension work for an autocross event coming up at the end of the month. I’ll probably do something similar to the way you did yours.
Dan
To Autometer Speedo and Tach
