The right engine for a '73 Stingray
I am new to this site and new to the world of Corvettes, having been a Harley man for many years. As a disabled vet, my troubles have caused me to give up the world of two-wheels an opt for four.
Initially, I had a '74, with a 500-600 hp crate engine. That one was destroyed just recently when something failed while driving home from the martial art club. As the car came to a stop in a bad section of highway, it was subsequently hit by a kid driving a Mitsubishi, who was doing 85 mph or more, and had dropped his lighter on the floor of his car. So, the 74, which was just starting to show some promise - with a fresh transmission and tuning of he motor - was totally destroyed.
That would have been the end of it, except the three kids were borrowing the car - and it had no insurance anyway. So, I have another Stingray now. However, the car needs some work before it is totally road-worthy. Those who owned it lied to me about a fair portion of the details. Its TH-400 transmission was failing, and it would seem it has some oil pressure woes - too much space around the rings.
This brings me to the following questions which I leave to your combined experience to provide me with guidance.
First, one of the lies I was handed was that the motor had only been in the car for two years - the producers of this 350 engine have been out of business for nine years. Other indicators suggest that the car may have been sitting in the previous owners garage for some time - perhaps more than three to five years.
It looked to be in remarkable shape - but the tranny and engine thing suggest serious trouble. While I am getting the tranny sorted out now, it will be some time before I can afford to repair or replace the motor - unless I land a good job which I have recently applied for.
So here's the crux of the question - Assuming I can get the car to a reasonable safety level by addressing the bad power steering ram and the transmission woes - will ten psi on the oil pressure actually be enough to operate the car until I can address that problem? Also, if I get the new job, I will have enough money in about four months to afford any of the new crate engines available now. I have looked at each of these, and would like to know what would be the easiest, safest and most efficient engine I could install? I have read threads on this forum referencing the 454 and the 502 engines - and I would like something as powerful as what was in the 74. I have also noted a new engine - a 572? Assuming this pans out the way I want, what should I put in the car - and if I put in a massive motor - what would be the combination of beefed-up suspension parts I would need - and what transmission would pair well?
I am a lot of things - but I am no 4-wheel mechanic. Much of this is foreign to me. And since I'm a disabled vet, working on the car myself is not so easy. I have the car at a reputable shop now - but I want a game-plan before I get the razzle-dazzle treatment from the mechanics there. I would like to at least understand a little of what I am talking about. Can you help me with this?
-Dave
Your engine: You mentioned you had a 600hp motor. was it a SB or BB engine? You can put either engine between those sexy curves. If you like brute power and large amounts of torque, and dont mind suffering from low gas mileage BB is the answer. If you like an engine capable of respectable HP and torque SB is the way to go (383 ci). I'm not sure as what type of suspension parts you would need but your stock rear end should be able to handle up to 300-400hp. The guys here are a great group of people who can impart a lot of knowledge and experience. Hope this helps you a little and welcome to the forum
Is this even possible? What would need to be changed to make this work?
-Dave
1. If the TH400 is in bad shape, get it repaired at a qualified shop...cost maybe in the 500-700 dollar range.
2. 10 # of oil pressure is not much....the engine bearings are about to go south. Suggest an inexpensive crate, in the form of 300 HP for about 1500.00. When you get financialy stable, then you can add a cam, heads, and all the other good stuff, but for now, the base crate will get you going and the vette will run and be trouble free.
-Dave
And my respect and gratitude to you for your service to us all.
So, I'm trying to get a game-plan that I can present to the shop the car is currently being overhauled in. They do exclusively Corvettes, so it's in the right place - I just want to know a little bit about what would be best for this car. I had a car with a 500+ horsepower engine on board. It was a scream, until it got rammed by some kids doing about 90 in an eclipse. They ended up underneath the Vette, and I was sitting in an accordion.
So I guess I'm looking at best case scenario - I get the job, can do the job for at least five or six months - and therfore can do almost anything as far as the engine and suspension.
What would you folks recommend? Give me a list.
And thank you to the individual who said thank you to me ref. the veteran thing. I was in Somalia. That was my last gig. I was there for seven months - from the beginning to the end of the operation. It was an honor to be able to serve you, and even with all the water under the bridge - I wouldn't trade a second of it. We did make a difference.
Would putting in a heavy-weight oil - 40 or 50 weight increase the pressure to safe levels?
Also would a temporary fix be to put a high-volume oil pump in for the time being. Isn't the issue volume, not pressure?
I just need the thing to carry me a few miles back and forth to the new job for about two to three months. Then it can go in for a complete replacement of the engine.
I hate when people lie to you when selling something as vital as a car or bike (basically your transportation). Makes me sick to think about it.
On the engine thing, I just bought the car, and put it in the shop immediately. But I think it was sitting for years. The oil was like water. Would putting in heavier oil - 40 or 50 weight possibly raise the pressure to a safe level temporarily? Or what about a higher volume oil pump? It gives no indications that it is burning oil. It is puzzling to me.
