Combustion chamber and piston dish shape
Old Jan 18, 2006 | 09:10 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Combustion chamber and piston dish shape
OK so I am building a forced induction motor, and since I am po' I tend to agonize over every little thing.
So as far as I can tell chamber development lead to the kidney/heart shaped chamber for increased power, economy, less detonation, and increased compression reliably. So what about the piston on the other side. I would assume that it would have as much to do with the flame fronts and whatever as the chamber does.
So my options are
1.) Cheap - D-shaped cup
2.) Not so cheap - symetrical reliefs
3.) Expensive - Asymetrical relief(like my chamber bigger relief for the bigger valve.
Old Jan 18, 2006 | 09:47 PM
mrvette's Avatar
mrvette
Guru, from a tech aspect I can say I dunno crap, from a bux side ....
you pursue this project you most definately will continue to be 'po' but.......
it will put a hell of a smile on your face....
GENE
Old Jan 19, 2006 | 03:15 AM
Solid LT1's Avatar
Solid LT1
Any of the 3 options are OK if you are retaining proper quench clearance rather than putting the pistons down into the bore (0.040" piston top to cylinder head clearance.) #3 is the best solution but, any of the 3 methods will work better than a full "bowl type" dish on the piston top. Make sure the rings are 0.250-0.300" down too and go with 0.927X2.75 or 3.00" long piston pins NONE! of the 2.50-2.25" long normally aspirated "race" stuff if your going to put some boost in the motor.
Old Jan 19, 2006 | 06:27 AM
Guru_4_hire
Cruise-In V Veteran
Yeah I think I have been underplaying it. I think a solid roller cam to replace the hydraulic one, and move the redline up to 6800rpm or so with shift points around 6300 would do me a lot of good.
I wouldnt need to change anything except my cam really.
But all I want is 650hp.
Old Jan 19, 2006 | 06:31 AM
Guru_4_hire
Cruise-In V Veteran
I was looking at the sealed-power/TRW piston (summit part number)
TRW-L2441F30
The SRP piston
SRP-139632
the JE piston(asymetrical)
JEP-130969-8
If the D-shaped cup will work than I just might buy the speed-pros. If there isnt 200-300 dollar improvement to the other shaped dish.
Old Jan 19, 2006 | 05:30 PM
Guru_4_hire
Cruise-In V Veteran
Nobody?
Old Jan 19, 2006 | 08:37 PM
Guru_4_hire
Cruise-In V Veteran
I guess I am just gonna have to spring for the JE pistons. Damn I really didnt want too but I cant find an alternative that has an asymetrical dish designed to mimic the fastburn chamber, and maintain quench.
The turbo guys on the turbo forum are disturbingly silent. Do I ask hard questions or something?
Old Jan 20, 2006 | 05:04 PM
Guru_4_hire
Cruise-In V Veteran
OK what about pistons with a circular dish? Like diamond, arias, and Probe sell?
Old Jan 20, 2006 | 06:26 PM
Guru_4_hire
Cruise-In V Veteran
I am assuming that the standard deck height is 9.025
Wow
So a 3.48" stroke + 5.7" rod and a 1.56 compression height only gets me 9" so my pistons will be .025 down in the hole to start with. add a .041 standard head gasket and I am at an unacceptable .066 quench. so I need to lose about half that distance somewhere.
I can get a .027 thick Cometic MLS head gasket that takes me down to .052
I suppose if I decked the block to 9.010 I could get .37 quench which will wonderfully.
Dang.
Old Jan 20, 2006 | 06:28 PM
Monty's Avatar
Monty
Here's what my piston from my 1200hp TT SBC427 looked like.
I already had the Dart CNC 18* heads from the engine's previous incarnation as a 12:1 compression NA engine, and I wasn't about to take the grinder to the CNC machined combustion chamber to enlarge them or go with a piston with a too short compression height - not good for combustion efficiency and not good for forced induction apps due to the ring location. 1.175" compression height works perfectly fine and you can safely locate your rings (as mentioned in an earlier post) although the oil ring will need a support but that's no big deal.. Besides, I beleive in the small, efficient combustion chamber to promote flame travel and uniform A/F ratio. In order to drop the compression from 12:1 to 8.5:1 I had to go with a fully dished custom piston from JE. There are some benefits to this design in that the cylinder pressure is applied more uniformly against the piston and the valves are greatly unshrouded, but you do give up some traditional quech area although you still ahve some around the circumeference of the chamber. Even so, you'll notice I still had to have a slight valve relief for the intake valve as I was running a 2.180" valve.
Old Jan 20, 2006 | 09:05 PM
Guru_4_hire
Cruise-In V Veteran
So the circular dish is OK. Thats good to know.
Thanks.
Probe makes a forged piston similiar to that for 329 bucks for a set of 8. Its not a JE but I am also not planning on running as much boost as you.
As a question monty how much did the CV products pully system run you?
Old Jan 20, 2006 | 10:27 PM
Solid LT1's Avatar
Solid LT1
Full dish pistons like the ones in the photo leave some of the mixture unburn but, do help with piston cooling in a supercharged motor (or turbocharged engine.) The mixture uniformity and burning are much better with a "D" or assymetrical dish type piston. You can use anything you want but, I would go with the J&E pistons in my motor.
Old Jan 21, 2006 | 08:46 AM
Guru_4_hire
Cruise-In V Veteran
The thing is I am trying to avoid 700 dollar pistons. 400-500 is much more condusive to my life.
Is there somebody that sells slugs to be machined?
Old Jan 21, 2006 | 08:56 AM
Guru_4_hire
Cruise-In V Veteran
So a D-shaped cup even though it bears no resemblence to the chamber will burn fuel better?
But the full dish will keep the piston cooler avoiding hot spots.
Interesting.
Old Jan 21, 2006 | 11:08 AM
Monty's Avatar
Monty
I don't recall exactly, and it appears to be something I forgot to document on my website, but they are not overly expensive. I plan on using them again on my TT LS7X 427.
Old Jan 21, 2006 | 11:59 AM
Guru_4_hire
Cruise-In V Veteran
Good deal. I am sort doing my turbo project on a budget. So I agonize over everything, and then compromise my agonization with what I can actually afford.
I did come up with a new top-shelf fluidampr off of ebay for a song. So I am happy there.
Old Jan 21, 2006 | 02:50 PM
Guru_4_hire
Cruise-In V Veteran
Dang how hard is it too pick out a 8.5-9:1 piston. I mean come on.
There is just so much.
To Combustion chamber and piston dish shape
Old Jan 21, 2006 | 03:00 PM
Guru_4_hire
Cruise-In V Veteran
I can get wiseco pistons for 8.7 or so compression with rings and pins for 514 bucks. they have symetrical reliefs but I guess it will have to do. I will just save up some more money and have them ceramic coated by swaintech. that will help keep them cool.
also I think there is a TRW piston I could get but after I add in rings its already at the wiseco price.
Old Jan 21, 2006 | 03:41 PM
redc3's Avatar
redc3
all i can add is that your gonna have to be careful with the comp. ratio with a blown engine. youll want to stay around 9:1 or lower. as for the redline you mentioned, i cant see the need for the solid cam for the revs you mentioned. i have hydraulic cam and have to set my rev limiter on 7000 or it will grenade its self, it revs so easily. it was common place to run whole races with our dirt cars at 6500-6900 rpms, with hydraulic cams.
Old Jan 21, 2006 | 03:42 PM
Twin_Turbo's Avatar
Twin_Turbo
can't find pics of my pistons, mine are sort of a mis-shaped peanut shape.
