OK, so here's the story. Within the last month or so, the vette ('80) started to make an airy sort of tick noise. The noise was most noticeable when i was accelerating from either a slow speed or stop. The noise is made in timing with the turning of the engine. I checked briefly to see if anything was loose, but i don't think that it is the case. the noise doesn't seem to hinder the performance of the car any but the noise still bothers me. It seems to be coming from the left side of the engine compartment. I don't know what the problem is or if you guys can help on such limited info. Thanks :cheers:
Re: Help me identify my problem please! (vettepowA)
I would first check the donut seal between the manifold/header and the exhaust pipe. Might also be the manifold/header gaskets themselves. Good luck! :chevy
Take a length of tubing and place one end against your ear. Move the other end around through the engine compartment to isolate the exact area where the tick is coming from. I used this method yesterday to find a loose vacuum line that was hissing. It's a poor mans stethoscope.
I had a similar problem in my last car. ('76 L-48) It sounded like valve clatter, but it was a little deeper sound. It turned out to be the flexplate to torque-converter bolts. I removed the inspection plate and tightened all of the bolts. They all needed between 1/2 and 3/4 of a turn. Never had any more problems after that. Good luck.
