Rear spring
Old Jan 20, 2006 | 09:05 AM
bashcraft's Avatar
bashcraft
Default Rear spring
Aside from the obvious, what's the difference between a 7 leaf and a 9 leaf spring? My '69 has a 9 leaf, but I think someone just added 2 leafs to a 7. I've been looking around and found both the 7 and 9, but can't find any info about the different applications.
Old Jan 20, 2006 | 09:45 AM
Konkol1's Avatar
Konkol1
Not entirely sure, but I believe the 9 leaf spring was the standard spring, and the 7 leaf spring was used for the optional suspension available in the 70's. Gymkhana? comes to mind.
Dale in Badgerland
Old Jan 20, 2006 | 09:57 AM
Ganey's Avatar
Ganey
9 is standard, 7 is higher rate & used in Hi Perf. sus. option like FE-7.
Old Jan 20, 2006 | 11:33 AM
bashcraft's Avatar
bashcraft
It has the Gymkhana front springs, but someone has definately added 2 leafs to a 7 leaf spring. You can tell because they're wider and have been ground down in the middle to clear the mounting bolts.
To Rear spring
