I have ordered stock rotors for my '66 project and have a question regarding the front rotors. I have drilled out rivets on the rears before and just used the wheel nuts to hold the system together. Is the procedure the same for the fronts? I have never done fronts before, but am hoping it is the same: drill out the rotors and use the lug nuts. Am I correct in my assumptions?
I plan to check runout once installed.
Thanks, Ralph
PS: after posting this thread I did a search and found the answer (same as rear). Should be more proactive. If anybody has any additional suggestions, they would be welcome.
Center punch, step drill, drill 5/16" bit just past the rivet head and use a cold chisel across the face of the rivet to cut it in 1/2 then drive out the body. tap the hole 3/8-24 and countersink the rotor to bolt it on and dial in the runout.
Glad to help Ralph, how's my viking friend been-LOL
Go to www.Mcmaster.com and you'll find everything you need. in fact since I like you the part number is 91253A351 3/8-24 x 5/8 steel flat heads. You'll need a 3/8-24 tap and a countersink. This iron is very easy to machine, I do it in a drill press but a hand drill would work too.
Don't use a tap size drill in the rivet hole,it's just a little bigger then the drill anyway so it should be a nice job. You can do this with the rears too, the spindle doesn't have to be removed for this job.
I just finished up a T arm and I dialed it in to .002" with some SS shim stock. This was with new rotors and old spindles. The spindles were not the cause of the runout the rotors were. With .002 endplay and .002 runout the stock lip seals in the calipers will work great.
Good luck and let me know how you make out with it.
