Motor "Does Rotate"
Old Jan 21, 2006 | 06:33 AM
Greenwood79's Avatar
Greenwood79
Default Motor "Does Rotate"
Morning guys....Need your opinion on the phrase above....What exactly does this mean.."The motor does rotate"?
If the motor rotates, should I be able to get it started?
What could be wrong with the motor?
would appreciate your replies....
Thanks..
Andy
Old Jan 21, 2006 | 06:57 AM
kb2fzq's Avatar
kb2fzq
Just because the motor turns over, "rotates" as you say, doesn't mean it'll start...need gas and spark....ya got those?
Old Jan 21, 2006 | 07:37 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
It means that nothing is "siezed" inside the engine. i.e. rusted, bent or broken.
Old Jan 21, 2006 | 08:40 AM
Greenwood79
Thanks Jug....Bothers me big time when that quote is said..Car is in Kansas and I am in Penna., so.....
Keep the replies coming!
Thanks again..
Andy
Old Jan 21, 2006 | 09:27 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
I was reading an article in Corvette Enthusiast last night about what to do in that situation. It said if the motor turns freely then the thing to do is drain all the fluids and change the filter. Then disable the ignition and turn the motor over with the starter a dozen times or so to get all the components lubed. Then it's compression check time. If all the cylinders are in the same range you can move on to hooking up the ignition and try to get it to start.
I realize you're a long way away from the car, but thought that might be useful info.
Old Jan 21, 2006 | 09:39 AM
kb2fzq's Avatar
kb2fzq
Thanks..
Andy
Are you comtemplating purchasing this vehicle? Is that the inside info and you don't want to buy a lemon via long distance??
Old Jan 21, 2006 | 11:15 AM
evalu8r's Avatar
evalu8r
Compression
Old Jan 21, 2006 | 11:31 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
What are you buying? A car or just the engine? Quite literally in reference to just the engine, "it rotates" could be taken to mean that it's on an engine stand and the engine block does rotate.
Old Jan 21, 2006 | 12:36 PM
Greenwood79
It's a vette..not just an engine on a stand. I appreciate all the replies so far...Makes it easier to speak with the owner of this vehicle.
Andy
Old Jan 22, 2006 | 09:56 AM
BB68Vett's Avatar
BB68Vett
Is this the Mako Shark II replica for sale on Ebay? The car looks OK (needs some work) but who knows what is going on inside the motor. Just because the motor rotates doesn't mean it runs.
FYI, there is some discussion of this car on a thread located at makoshark2.com. For a custom type car, I think I would make my bid contingent on an inspection or inspect before bidding. There could be some custom pieces that can't be located and will need to be fabbed. Guys on makoshark2.com think that it is pretty well complete though.
Old Jan 22, 2006 | 10:10 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
and just cause it rotates doesn't mean anything relative to bearings, piston rings,cracked water jackets, worn cam lobes etc etc etc.....rotating is good but a trashed engine can still rotate
Old Jan 22, 2006 | 10:35 AM
Kilroy1024's Avatar
Kilroy1024
An engine with a hole blown in a piston can rotate.
An engine with a cracked block can rotate.
Old Jan 22, 2006 | 10:41 AM
carl a's Avatar
carl a
and one with all the babbitt gone off the bearings still rotates,,will blow in future,,but still rotates
Old Jan 22, 2006 | 11:12 AM
Twin_Turbo's Avatar
Twin_Turbo
I agree....it only says nothing has seized up to the point where it won't rotate, it says nothing about the engine conditions, bearings could be shot, big ends stretched, bores shot..no compression..al kind of nastyness. Without hearing and seeing actually running you are taking a gamble if you don't inspect the internals.
Old Jan 22, 2006 | 12:57 PM
kb2fzq's Avatar
kb2fzq
...unless your only paying 100 bucks for it all, then you (might) win...
Old Jan 22, 2006 | 03:44 PM
enkeivette's Avatar
enkeivette
And I destroyed the bearings on my motorcycle engine, but it still rotates... kinda.
Old Jan 22, 2006 | 05:41 PM
Greenwood79
Thanks Guys..Appreciate the comments.
Andy
To Motor "Does Rotate"
