Engine swap?
Old Jan 21, 2006 | 08:32 PM
NewFoundHobby's Avatar
NewFoundHobby
Cruising
Default Engine swap?
I have a 350 in my 78 and I was wondering weither to put a new/bigger engine in it or just dress the old one up. its the origional engine and has 91k miles on it
any advice would be nice
Old Jan 21, 2006 | 08:38 PM
David Ey's Avatar
David Ey
I liked the idea of a new, more hp engine so,........383 for my 78
Old Jan 21, 2006 | 08:58 PM
kona's Avatar
kona
How does the car run? What are you going to do with the car daily driver occasional cruiser? If you have lots of bucks and nothing better to do with them I also will give my vote for new motor.
If what you got does the job and your happy spend a few bucks dressing up.
Kona
Old Jan 21, 2006 | 09:01 PM
NewFoundHobby
Cruising
The car runs well after warming up and I drive it pretty much daily. I am thinking about putting a new exhuast system and intake manifold.... nothing big.
Old Jan 21, 2006 | 09:07 PM
David Ey's Avatar
David Ey
I really like the 383 with 200r4 trans. The torque curve is almost straight, ie plenty at any rpm. I only drive the car for fun and love crusing 70 at 2100rpm in od. Punch it and do 100 in just seconds. I just can't say enough about these strokers. The old 350 only had 50k miles but this motor really makes me smile big there is sooo much diference.
Old Jan 21, 2006 | 09:10 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
its all about $$$ figure out what you want to spend and go for it......$3K and you can build that engine you have to be a barn stormer or you can buy a crate motor for that...good luck...there are almow too many options....you need to come up with some boundaries to this proposition
Old Jan 21, 2006 | 11:05 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Bigger is better.
Old Jan 21, 2006 | 11:19 PM
ThereIsNoSpoon's Avatar
ThereIsNoSpoon
If I had the money I'd be getting a 383 tomorrow. It's all about what you're willing to spend.
Old Jan 21, 2006 | 11:31 PM
seaboltm's Avatar
seaboltm
if you have something like a l48, swap the engine;
i have a 73, original l48 car, now a zz4 fastburn car.
i would buy a zz4 base engine and add the hot cam and heads; much cheaper than buying the zz4 fastburn engine.
Old Jan 22, 2006 | 08:52 AM
markdtn's Avatar
markdtn
For a nice driver I'd Tune-Port fuel inject your stock bottom end. Should give a noticable boost in power and mileage.
Old Jan 22, 2006 | 11:21 AM
NewFoundHobby
Cruising
Im not looking for big hp right now, only about 250-300. and I would like to spend as little as possible. OH YA and i want it to look nice .
so would I rebuild the one i have and put some stuff on it or just buy a 383.... also, i dont have any idea on where to start so which one would cost less to have it done? although i do have a guy down the street that knows his stuff..
Old Jan 22, 2006 | 02:14 PM
BerniesVette's Avatar
BerniesVette
Why not buy a used 400 cube stock motor, build it and be ahead of the curve. Just a mild build would get you the horses you want with a very reliable almost stock engine. If you really want to get crazy, stroke the 400 and really get some bang for your buck! Just a thought.
Bernie
Old Jan 22, 2006 | 08:54 PM
markdtn's Avatar
markdtn
If all you want is 250-300hp then Tuned-Port is right on the money. Visual appeal is awesome.
Old Jan 22, 2006 | 09:06 PM
corvetteatv7's Avatar
corvetteatv7
Bernie
Thats kinda what i am doing this summer. Got a 400ci sb and will build it to about 500hp w/o stroking. Should be able to do it for under 4k from what the research tells me. jmo
Old Jan 22, 2006 | 09:14 PM
marshrat99's Avatar
marshrat99
Before I pulled & stored my numbers matching L82 on my 79 and replaced it with a custom 355, I did a complete tuneup (timing, wires, plugs, distributor cap, etc), rebuilt the carb and replaced the EGR valve and vacuum triggers (not the correct name but they are those devices controlling vacuum based on engine temp and screw into the intake manifold). Just these few simple things made a tremendous performance improvement.
Old Jan 22, 2006 | 09:37 PM
NewFoundHobby
Cruising
ok, and how much did it cost to do all that?
oh ya, and i think that I have a l48 in mine, not sure though. Im sorta new at all this
Old Jan 22, 2006 | 09:57 PM
marshrat99's Avatar
marshrat99
It was a while back so I don't remember exactly but was certainly less than $100 in total. Of course I don't mind getting my hands dirty and do the work myself.
Old Jan 22, 2006 | 11:23 PM
NewFoundHobby
Cruising
low cost is always good, sounds like a plan
time to get to work!
To Engine swap?
