17"&18" on C3
I am waiting a little on comments from a friend on what she thinks a good style is (I could care less really) but I am ordering the some of the Centerline all forged numbers. You get to spec the offset on all of them for no charge and I know the 18x8" fit better even than the 17x8", but do the 18x 9.5"?
I would like to use those rims to use 265/40 YR18 Pilots which are 26.3" diameter and 10.7" section (and the heaviest load rating) - they spec 9" rims.
If I'm "stuck" with the 8" I can only use the 245/40's, which are only 25.7" and 9.8".
Or, are they being picky on recommending 9" for those tires? Can you put those on 8" rims safely? (I push this car very, very hard with lots of miles on all sorts of roads.) The diameter, not the section, is my big concern - I want maximum top speed for minimum RPM.
I have the complete VBP front and rear suspension and no offset trailing arms and most certainly do not wish to remove the sway bars.
The brakes are aftermarket, but regular dimensions. Honestly, since the nose and tail are '82's I do not know the wheel wells aren't also (I did not do this - it came that way.)
Mine is a '75 with no flares yet, although I will put them on later for considerably wider meats, when I have a real engine.
Also, what offset should I ask for from Centerline?
These are one type I am considering:
http://www.centerlinewheels.com/whee..._id=1&sw_id=13
Thanks for any advice...
I can't WAIT to have her back on the road and half way COMPLETE!!!
I basically went through the various threads and compiled most of what was said re fitting bigger rims (mainly TTII's) to C3's, because I am about to buy a set and want to make the right choice as I am in Australia and don't want to get the wrong sizes.
Here is the thread: http://forums.corvetteforum.com/show...325&forum_id=3
cosmicvette
