M22 Rebuild
Old Jan 23, 2006 | 10:24 AM
69/03vette's Avatar
69/03vette
Default M22 Rebuild
I got my M22 rebuilt (was jumping out of third gear) The rebuilder put in a new 2nd and 3rd gear as well as bearings, bushings, syncros..... and everything alse that goes with a rebuild. Reinstalled this weekend and now I can't even fast shift into 2nd or 3rd. If you drive like an old lady it works ok. The rebuilder said I have to drive it and break it in. I never heard of breaking in a manual trans before, it either works or it don't. I think he did'nt do something right. A buddy asked me if the builder timed the gears when putting it together and I assume he did if this is a part of the rebuild. Does anyone know if timing of the gears would cause this problem?
Old Jan 23, 2006 | 11:01 AM
redvetracr's Avatar
redvetracr
new GM gears are hard to come by, did your rebuilder use NOS GM stuff or "offshore"?? "Timing gears"?? never heard that one before!!
...redvetracr
Old Jan 23, 2006 | 11:40 AM
waterplay's Avatar
waterplay
Not sure but Keisler talks about noticeably firmer shifts for the first 500-1000 miles. It sounds to me that your builder could be telling you the truth. Give it some time and see if it gets better.
Old Jan 23, 2006 | 12:12 PM
Kid Vette's Avatar
Kid Vette
Are you sure the linkage is adjusted properly?
Old Jan 23, 2006 | 03:22 PM
Kalway's Avatar
Kalway
Well gears rarely fit together perfectly right away so I'd suspect that they need some wear to fit right. Drive it 500 - 1000 miles and then see how it feels.
Old Jan 23, 2006 | 03:26 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
I just had my T10 rebuilt the end of summer and it was real tight too. I have several hundred miles on it and it gets better each time I take it out.
I have never heard of "timing" the gears & I grew up around cars.
Old Jan 23, 2006 | 04:40 PM
GTR1999's Avatar
GTR1999
If he changed 2nd and 3rd gear but not the countershaft then you'll have new gears running against old. This usually is a noise issue since thegears themself do not move. The syncros lock on each gear buy a sliding hub (aka a slider). When rebuilding the fit of the gear,syncro and slider should be free. The dog retainer springs in the kits are usually longer and may be dragging the engagement of the syncro's. If should be a firm but certainly drivable condition.
I don't know what timing he was referring to? If you get an explanation please post it.
Old Jan 23, 2006 | 05:18 PM
comp's Avatar
comp
clutch is adjusted right ??
Old Jan 23, 2006 | 06:30 PM
James B's Avatar
James B
Mine was stiff as well even with 200 miles on it, shifts great now with over 1000
Old Jan 23, 2006 | 08:10 PM
JohnFromVentura's Avatar
JohnFromVentura
I put my 60 T-10 together with all new collars, forks and synchro rings and it wouldn’t even shift outside the car. I had to go back and grind .010/side off of the forks before it would work. It shift great now in the car.
To M22 Rebuild
