speedo/tranny driven gear help!!
Old Jan 23, 2006 | 08:18 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Default speedo/tranny driven gear help!!
My 4 speed 76 vette has a green 22 tooth driven gear. The speedometer is off, and I've done calculations and have found that I need a 19 tooth to even things out. I ordered a 19 tooth natural color driven gear from Chevrolet that came in today.
The green (original) driven gear is approx 1 7/8" diameter across the gear teeth. THe new one, is only 1 3/4" in diameter. I installed it not noticing and went for a test drive, got acouple of hundred feet from the house and noticed the speedo wasn't working at all.
Took it out, put it back in, figured I just didn't seat it right. No difference. PUlled it out, inpsected it, no stripped teeth, compared to the green on and noted the measurement difference above.
So, my problem - none of the online sites I find say that there even was a green, 22 tooth, 1 7/8" driven gear. Only a grey one.
In any event, where can I get the right 1 7/8" 19 tooth driven gear???
Old Jan 23, 2006 | 08:19 PM
ruby76's Avatar
ruby76
Did I move enough teeth to need a different drive gear??? need help, thought this was going to be an easy 15 minute job.
From the following website:
http://www.tciauto.com/components/speedometer_gears.htm
my green 22 tooth doesn't exist.......
Old Jan 23, 2006 | 08:21 PM
Greg's Avatar
Greg
Just another Corvette guy
Hi Jeremy,
Was your speedo reading too fast or too slow with the 22 tooth gear?
What rear end gears are you running?
Greg
Old Jan 23, 2006 | 08:31 PM
ruby76's Avatar
ruby76
Greg, I don't know what the rear is, I can only guess it is 3.55 or 3.73 based off of the rpms at/near 70 mph = 33-3500 rpms
The speedometer reads slow by 10-12mph with the 22 tooth gear in place. 19 teeth reduction should increase the speedometer speed about 12 mph (I came to that conclusion at some point)
Old Jan 23, 2006 | 08:37 PM
Greg's Avatar
Greg
Jeremy I'm running 3.55's with a four speed and stock tire height. I have a white/gray 18 tooth driven gear and I'm reading way too fast.
Greg
Old Jan 23, 2006 | 08:46 PM
ruby76's Avatar
ruby76
Hmm.. The tranny is not original, if that makes a difference. How fast is way fast?
Here is my logic
19teeth/22 teeth = 86 % reduction in speedometer gear (increased speed on speedometer
60mph/70mph = 85 %, so going from 22 teeth to 19teeth, should increase my speedometer speed 86 percent, or from 60 to 70 mph (69.47 actual mph)
But my confusion is the non-existant 22 tooth green driven gear that I just put back in. I can't really tell the color/material of the drive gear.
Old Jan 23, 2006 | 08:52 PM
Greg's Avatar
Greg
I should have metered the discrepancy before I pulled my trans. When travelling 70mph I was reading approx. 90mph. I have the orig. trans and diff. Previous owner cured his bouncing speedo by installing the new driven gear. He just wasn't that fussy about getting the correct one. 19 teeth may be right for your application from the algebra you've "ciphered". I know this can be a bitch to get right sometimes.
Old Jan 24, 2006 | 08:34 AM
ruby76's Avatar
ruby76
greg, thanks for responding.
Anyone else w/ any information? did I move too far down the driven gear road and now need a new drive gear?
The diameter of the two driven gears is the reason the new one (smaller diameter) won't contact the drive gear teeth.
Jeremy
Old Jan 24, 2006 | 09:23 AM
GasketDude's Avatar
GasketDude
Few years back I was installing a 200R4 in my Olds convertible and started looking for speedo info. Been collecting GM info as a result, your green 22 teeth driven = GM#3860345, though it's likely that this number has been superseded many times by now.
Let's start from the basics, tire size(P255-?), gear ratio, drive gear count, and driven gear count to come up with a combination for your setup. I think you may just be looking at the wrong transmission type when picking your gear number.
Later.
Old Jan 24, 2006 | 10:04 AM
WESCH's Avatar
WESCH
Hi
OK, I have the same problem. Had a clear driven gear in my M21 close ratio with 3.70 rear end.
When I installed the GM T56 Viper 6 speed tranny, I got told that I can use the original M21 gear driven setup and thats what I did.
The clear gear was hard to insert and stripped threads within a few hundret miles.
I installed a red one with more teeth and it's holding fine, but reads wrong.
The red gear outside diameter is much less than the clear one was.
I guess, you can not just install different gears without also changing the drive gear inside the tranny.
I will have to contact D&D to ask what they recommend as the T56 is from them.
Funny enough, all vendors carry all the different driven gears, but say nowhere what drive gear is required.
Günther
Old Jan 24, 2006 | 03:00 PM
Greg's Avatar
Greg
Jeremy,
I think my problem is solved. I just spoke with my guy at the local Chev. dealer. He went to the parts book and apparently is has a chart in the back to use for application. My 3.55:1 rear with M20 4 speed calls for a blue, 20 tooth driven gear, part number 3987920 and he has it in stock. Drive gear should remain the same. This sounds correct, I'll let you know after re-assembly. If you'd like to try my 18 tooth driven gear in yours I'd be happy to send it to you.
Greg
Old Jan 24, 2006 | 03:19 PM
ruby76's Avatar
ruby76
Originally Posted by Greg
Jeremy,
Greg
greg, can you measure the diameter of the gear? Like I said my existing 22 tooth one measured 1 7/8" whereas teh replacement I ordered was too small at 1 3/4"
My tires are 255 60 15's, rear end? no clue probably 3.55 or 3.73, drive gear, can't tell what color/material it is, can barely see it through the very small opening in the side of the tailshaft.
As mentioned by WESCH, Why doesn't anybody know what drive gear is required given the driven gear??? I'll call the chevy parts department in a few minutes
Old Jan 24, 2006 | 03:45 PM
Greg's Avatar
Greg
I'm on my way to the tranny shop in a few minutes. I'll pick up the gear when I'm there, measure the diameter and re-post.
Old Jan 24, 2006 | 05:44 PM
Greg's Avatar
Greg
Jeremy is your car an automatic? My 4 speed gear is way smaller than your measurements. Approx. 7/8" diameter and approx. 1 & 3/4" circumfrence. If you do have a 4 speed and would like to try this one, just say the word.
Greg
Old Jan 25, 2006 | 08:41 AM
ruby76's Avatar
ruby76
Greg
The Chevrolet shop said - "we've never heard of that before, you'd better go to a speedometer shop"
DOH!!!!!!!!!!!!!!!!
your right, I meant 3/4" vs 7/8" diameter, i got too finger happy when typing and added a 1. :o
No, mines a 4 speed. I used a caliper to measure across the teeth of the driven gear. The one that works (but wrong speed on speedo) is 7/8" across the teeth. The one that doesn't is 3/4". Sounds like your's is like the one I just bought. Thanks for the offer though.
Jeremy
Old Jan 26, 2006 | 02:36 PM
GasketDude's Avatar
GasketDude
What is the part number for the 19 tooth driven gear you got from GM?
My chart shows a #3987919 Natural(white/cream). TCI chart shows same and lists a size of 2.25"L, .305" shaft dia., and .800" gear diameter. This is the same as a TH350
Based on your 27" tire (255/60/15"), 3.55 gear, 7 tooth drive (stock M21), your math is correct using a 19 tooth driven gear.
Later.
Old Jan 26, 2006 | 04:27 PM
ruby76's Avatar
ruby76
thanks guys, tomorrow Im working from home so I can stop by the speedo shop around my lunch break. I'll let everyone know what the outcome is.
.800 diameter? That is in between the 19tooth 3/4" (.75) andthe 22 tooth 7/8" (.875). Granted I don't have teh best of calipers to measure with
stay tuned..
To speedo/tranny driven gear help!!
Old Jan 26, 2006 | 11:01 PM
supercalvin's Avatar
supercalvin
http://www.700r4.com/speedoCalc/speedocalc.shtml
This is a great tool for determining the Drive Gear and Driven Gear.
Old Jan 27, 2006 | 08:42 AM
mooneyd's Avatar
mooneyd
You can't change the number of teeth and stay the same dia. Going to less teeth will be smaller in dia. To get them to mesh you need to move the driven gear closer to the drive gear. I don't know how the 4 speed speedo driven gear is mounted, but on my 700R4 the driven gear is in a small housing that mounts to the side of the tail housing and it can be rotated on an eccentic to change the center to center distance of the gears. There has to be some way to do this on yours, otherwise you have to change both gears to get the ratio you need and still maintain the same center distance.
Old Jan 27, 2006 | 09:42 AM
ruby76's Avatar
ruby76
The "carrier" on my 4speed is not adjustable, but I see your point about loosing teeth and thus the diameter. I wonder if there is a different carrier on the 4speed for different driven gears/diameter.
I really hope I don't need to change drive gears - I'll let you guys know in a couple.
off to the speedo shop.....
