Body Panel Installation Adhesive ??
Old Jan 23, 2006 | 09:21 PM
DR.Jay's Avatar
DR.Jay
Default Body Panel Installation Adhesive ??
I just recieved the last body panel today from Ecklers. I will begin puting the the front clip back together soon, and I will be using "Lord" product #127EZ/128EZ Fusor Plastic Structural Installation Adhesive (Slow-Set) This meets the gm spec for SMC fiberglass bonding.
Here is the product web site.
http://www.lord.com/Default.aspx?tabid=1193#127EZ128EZ
Has anyone used this product? Does anyone have any advice about body panel installation. I have read the assembly manual, and the book from GLAS-RA. I was thinking about using some 3M products. The boys at the local Chevy body shop made some recomendations that I checked into, The adhesive 3M #08116 was about $50 for ten oz, but the special applicator gun was around $349. The local "Lord" dealer had the GM spec adhesive for $37 for 10oz. I bought three tubes, and he threw in the applicator gun for free.
Thanks for the advice in advance.
DR. Jay
Old Jan 23, 2006 | 09:25 PM
comp's Avatar
comp
Old Jan 23, 2006 | 09:48 PM
big_G's Avatar
big_G
If you are going to use this to bond panels, be aware that some of these products are not compatible with body fillers, primers and top-coats. We don't use them where visible joints or seams will show. Please fully read all applicable literature before using this type of adhesive.
Old Jan 23, 2006 | 10:22 PM
DR.Jay's Avatar
DR.Jay
Thanks Big G.
I was going to order the "Lord" product #302 & 322 epoxy that Ecklers sells in quart cans (the industrial size) it met the GM spec for SMC fiberglass. Lord Product # 127 meets the same spec, but is in a tube dispenser. When I called Lord's tech support they recomended the #127
What Would you Recomend?
Old Jan 23, 2006 | 10:48 PM
big_G's Avatar
big_G
We use this..SMC Panel Adhesive 993...come visit us when you come to North Austin...
http://www.evercoat.com/productCategory.aspx
Old Jan 24, 2006 | 09:51 AM
Fred D. Zwiger's Avatar
Fred D. Zwiger
Default Panel Bonding
We sell and I have used Fusor 127 on many occations. It's a great product and gives plenty of work time. If you use it, see if you can borrow an air gun to get it out of the tube - much easier. also you can squirt it on card board and mix it with a spreader.
Old Jan 25, 2006 | 07:32 AM
DR.Jay's Avatar
DR.Jay
Thanks Gary.
I'll try to stop buy when I get a chance. I had stoped buy on X-mass Eve while on a parts run for to the Napa Store for some steel fuel tubeing I didn't think anyone would be there. I had just seen the sign out front. I didn't know that was your Shop. I should have checked your profile. Oops.
Gary I think your knowledge, and advice is great.
Thanks, Again.
Jason
To Body Panel Installation Adhesive ??
