Vortec Heads
Old Jan 24, 2006 | 01:22 PM
toupstrio's Avatar
toupstrio
Default Are these the Vortec Heads to buy?
Are these the votec heads to buy? Are they ok?
809-12558060 SB-Chevy Cast Iron Vortec Cylinder Head
170cc Intake Ports
64cc Combustion Chambers
1.940'' Int/1.500'' Exh Valves
.475'' Max Lift
Straight Plug
Assembled, Sold Individually
View Product
$249.99 Add to cart
Add to wish list
Old Jan 24, 2006 | 01:53 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
check out this part number from summit fully assembled
SUM-151124
Old Jan 24, 2006 | 02:29 PM
jackson's Avatar
jackson
At 67cc ... the summit vortecs aren't real GM ... and neither are these
http://www.motorville.com/tabloid/page_24.htm
but you can assemble those for a lot less than summit ... you can buy a kit (for 2 heads) with valves, springs, retainers, locks & studs for under $175.
Old Jan 24, 2006 | 04:23 PM
toupstrio's Avatar
toupstrio
Thanks for the information.
Old Jan 24, 2006 | 04:30 PM
TedH's Avatar
TedH
If you are intent on installing Vortec's, I'd recommend the following:
https://www.sdpc2000.com/cart.asp?ac...277&pid=229035
Old Jan 24, 2006 | 05:30 PM
toupstrio's Avatar
toupstrio
Not intent on the vortec's just everyone is saying the hp is better than even the 202 heads. I would rather stay with something i could use my same intake with.
Old Jan 24, 2006 | 08:18 PM
bobs77vet's Avatar
bobs77vet
theres lots of choice for your original style intake.....the vortec heads are good but so are lots of heads.
Old Jan 25, 2006 | 03:41 PM
toupstrio's Avatar
toupstrio
If I dont go with the vortec i think i should go with the 202 valves but what cc on the intake runner 180, 190, 200 Or what? Also what does cnc ported mean?
Old Jan 25, 2006 | 04:02 PM
TedH's Avatar
TedH
I'd recommend no more than 190cc intake runners unless you are going larger than 355ci. My understanding is that CNC is a type of machine that performs controlled porting of the combustion chamber and associated areas.
I believe CNC machines can also be used to take the unfiinished casting and bring to a finished, machined state.
Old Jan 25, 2006 | 04:04 PM
toupstrio's Avatar
toupstrio
[QUOTE=TedH]I'd recommend no more than 190cc intake runners unless you are going larger than 355ci. My understanding is that CNC is a type of machine that performs controlled porting of the combustion chamber and associated areas.[/QUOTE
Thanks am going with the stock L82 on bootem end. So I will look at the 190cc
To Vortec Heads
