Timing on a '81
Is it the same when on this '81, and if so, where is the disconnect?
with the ECM harness leading to the HEI distributor un-plugged.
Once plugged back in, the ECM will control the timing based upon
inputs to the system.
I'm going on memory, but the connector is a 4-prong pig-tail deal
generally located opposite the tach and distributor ground connections.
Bela P. Havasreti
I'm thinking the Q-Jet may need to be overhauled. What do you think?
is being set). Any number of types of failures can cause a code
to be set, and can cause the ECM to go into open-loop (aka limp-home)
mode and cause the symptom you describe.
See: http://www.corvettedoctor.com/1981_DTC_Codes.html
If you can't scan the code(s) I'd start with the easy stuff 1st.
The thin plastic line going from the rear of the carb base to the
manifold pressure sensor on the firewall can easily get loaded up
with "junk", which will cause out-of-range readings by the MAP
sensor and the ECM will go into open-loop. Remove the line and
blow carb cleaner through it to clear it out.
Also, at idle, you should readily hear the mixture control solenoid (inside
the carb bowl) clicking at 10 times per second. If the MCS has
failed, or the connector leading to it or the TPS sensor isn't secured
properly or has shorted, the ECM will go into open-loop mode.
The computers on the 1980 and 1981 models were fairly simple, and
a methodical understanding, evaluation & testing of each sensor /
component in the system (there aren't that many) should lead you
to the one(s) that have failed.
The E4ME carb tends to scare some folks off, but overhauling one
isn't much different than an earlier Q-Jet.... The difference being
possibly having to replace & adjust the mixture control solenoid
and the TPS sensor to factory specs (get Doug Roe's book if you
plan on overhauling the carb yourself).
Bela P. Havasreti
Cheers
I had a freind, who rebuilds carbs, go through mine and will be re-installing it today. According to him, there were problems with the carb, choke, and the high idle kickup for the A/C.
If the carb doesn't fixed the problem, then I guess I need to find someone who can run the codes. All the vacuum hoses have been replaced, but over the years, may not have been hookedup improperly. If that is the case, I will need to find a good souce for a vacuum hose schematic. One that will show me the proper vacuum hose layout.
You guys are great - It nice to be able troubleshoot like this. I have no problems rebuilding engines, bodywork, paint, and interiors, but when it comes down to electrical or vacuum, I'm the worse.
That E4ME is a bear and after 25 years, they really start showing their age. If it's running really rich, check those solenoids, because if it doesn't get a signal from the computer it runs at full rich.
Looks like my next step is to run the codes or unplug the darn thing. Since I'm in a state with no inspections, it is not a problem to unplug the computer and run manually.
How easy is it to unplug the computer without having the engine light come on?
again (intermittent) would cause the RPM to fluctuate
as you describe. Also look for vaccum leaks.
With the air cleaner off, wiggle the electrical connectors
that go to the carb (TPS on the drivers side front corner
area, MCS on the passenger side top). If you hear the MCS
solenoid clicking @ 10 times per second, it's working. If
the clicking noise (and RPM) fluctuates while your messing
with the connectors, something is amiss.
Personally, I think it's easier to fix the sensor problems than
it is to pull the gauge cluster apart to "kill" the check engine
light....
Bela P. Havasreti
light....
Bela P. Havasreti
