Click-click-click from front left wheel
Old Aug 6, 2001 | 10:47 PM
dlw's Avatar
dlw
Default Click-click-click from front left wheel
And its not a rock stuck in the tire. Bearing feels OK. Time to bleed brake lines??????????? :confused:
Old Aug 6, 2001 | 11:14 PM
dshrack's Avatar
dshrack
Default Re: Click-click-click from front left wheel (dlw)
Does it happen all the time?
Does it the frequency increase along with speed?
Does it happen just when the suspension moves?
Do you have a baseball card stuck in your spokes? (oops, this isn't the BMX forum...)
Old Aug 6, 2001 | 11:43 PM
KenSny's Avatar
KenSny
Default Re: Click-click-click from front left wheel (dshrack)
Is it the start of "time to replace the brake pads"?
Old Aug 7, 2001 | 07:32 PM
dlw's Avatar
dlw
I can here the clicking when going slow or fast. Brake pads are still good. When I spin the wheel in the garage it doesnt make the sound. Does it going staight or in curves and doesnt stop when the brakes are applied.??
Old Aug 7, 2001 | 09:07 PM
dath's Avatar
dath
Does the frequency increase with speed? I'd check for nails if you think it's not a rock. They can be more difficult to find, especially the headless variety. Try moving the wheel to another position (swap drivers and passenger side wheels) and see if the noise moves. That will definitely rule out the wheel/tire. Otherwise, I'm not sure, clicking? Vettes don't have CV joints!
-dath
[Modified by dath, 7:08 PM 8/7/2001]
Old Aug 7, 2001 | 09:14 PM
noxqsz's Avatar
noxqsz
dlw;
If you have rally wheels with trim rings and center caps, try removing them, first the ring, then the cap, and see if the sound persists. If it turns out to be the trim ring, look to see how the ring attaches to the wheel. If it's attached with clips that fit over the lip of the wheel, the only solution I know of is to replace the ring with one that attaches differently.
Old Aug 8, 2001 | 06:05 PM
70454's Avatar
70454
I agree with Nox. I had a similar problem and traced it to the trim ring.
Old Aug 8, 2001 | 06:28 PM
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
Default Re: Click-click-click from front left wheel (70454)
I had the dust shield rubbing the inner wheel on the front and wheel weights hitting the brake line clip on the rear.
Old Aug 8, 2001 | 06:33 PM
dlw's Avatar
dlw
Default Re: Click-click-click from front left wheel (KenSny)
I think the trim ring idea sounds good. I dont like the ones that are on there so this might be a good reason to get new ones. And I looked hard for a nail so i'll take the ring off to see what happens.
Thanks for the ideas.
To Click-click-click from front left wheel
