battery cables
Old Jan 24, 2006 | 06:43 PM
694speed350's Avatar
694speed350
Default battery cables
been fighting a battery problem for a while. started out car would click but not turn motor over charge battery over night car would crank and run. would drive the car about 5 miles watching ampmeter. showed high amps recharge and would settle down. figured the battery was going bad. last time recharged battery and all i got was a click. figured battery was toast. bought a new one today. same problem. just a click. the car is a '69 convert. 350/300 4 speed. my question is where and how do the battery cables run. i'm pretty sure the +12v cables are ok due to the click of the starter soleniod what i'm suspecting is the ground cable. but i would like to know how are the battery cables run in this chassis.
Old Jan 24, 2006 | 07:45 PM
Z-man's Avatar
Z-man
On my '70 (which I'm guessing is similar), the positive cable runs from the battery box above the transmission to the starter solenoid. The negative goes from the box directly to the frame back by the box.
There are two grounds that should be checked. One comes out of the large harness close to the starter and goes to the starter ground. The other ground is between the engine and the frame near one of the engine mounts.
Maybe your grounds are bad???
Good luck -
Old Jan 24, 2006 | 08:53 PM
694speed350
I'm hoping that is whats wrong. thanks for the reply.
Old Jan 25, 2006 | 10:18 AM
bb69's Avatar
bb69
My suggestion would be to replace the battery cable with welding cable. It's cheap, flexible, and sold by the foot in any gauge you need. Also, if your car is anything like mine, all the power distribution wiring will be showing its age. I completely rewired my power distribution per MAD Electronics suggestions, and there is a noticeable improvement. That's what I would recommend to anyone. If you're not familiar with them, do a search and you should find a lot of information.
Good luck.
Ken
Old Jan 25, 2006 | 12:24 PM
GUSTO14's Avatar
GUSTO14
694speed350
Have you checked the draw from the starter? Most service centers have an Inductive Ammeter similar to this one...
http://buy1.snapon.com/catalog/item....&group_ID=1477
By placing it over one of the battery cables and engaging the starter, you can see how much amperage the starter is drawing. Anytime you replace a battery with a new one (assuming it's a good one) and get the same clicking sound it's a good time to check the starter to eliminate it as a problem. It is easy to chase your tail on these things, so I would try to eliminate the easy stuff first. The spec's for starter draw are in most good service manuals and as I recall should be somewhere around 200 amps max. The good news is that with a bad starter, the needle will get buried on one of these gauges (600 amps!) and there will be little doubt of the problem.
If the draw is minimal or below 200 amps, I would then start troubleshooting the circuitry including cables.
Good luck... GUSTO
Old Jan 25, 2006 | 08:14 PM
694speed350
Really suspect the ground cables. head lights,tail lights don't work at all. checked from battery neg. to bird cage with ohm meter well over 1 meg resistance.
Old Jan 27, 2006 | 06:15 PM
694speed350
wen't down to borrowed garrage today temp broke 50f today (old guy can't take cold weather) to check out problem. jumpered grounds with jumper cables still nothing worked. finally hooked up small battery charger turned on hazard flashers guess what they worked which means that the battery cables are ok. charger slowly went up to 6 amps (its a 6 amp charger) and is still on 6amps. i'm suspecting the new battery is defective.
Old Jan 28, 2006 | 12:22 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Buy an Optima red-top.
Old Jan 28, 2006 | 06:26 AM
bb69's Avatar
bb69
I'm no expert, but I expect you are more likely to see ground problems with larger loads. The hazards don't draw much current, especially compared to the starter. Using a test lamp, an interior type light bulb works well, check the ground in several places. By putting a load across the connection, you will get a good idea if you're getting a good ground.
Ken
Old Jan 28, 2006 | 08:26 AM
kb2fzq's Avatar
kb2fzq
Originally Posted by GUSTO14
694speed350 It is easy to chase your tail on these things, so I would try to eliminate the easy stuff first. The spec's for starter draw are in most good service manuals and as I recall should be somewhere around 200 amps max. The good news is that with a bad starter, the needle will get buried on one of these gauges (600 amps!) and there will be little doubt of the problem.
If the draw is minimal or below 200 amps, I would then start troubleshooting the circuitry including cables. GUSTO
I agree...check the easy stuff first...I suspect ground problems if the lights don't work either...using that battery charger, you are bypassing any ground problems, IMO...make sure starter and frame grounds are good...and a defective battery?, well, we all know it COULD happen but these days, doubtful....good luck
To battery cables
