HEI ignition, checking timing
Old Jan 25, 2006 | 07:47 PM
7Deuce's Avatar
7Deuce
Default HEI ignition, checking timing
Advice needed for a novice. I recently purchased a 72 and want to check to see where the timing is set. Any tips/tricks to do this with HEI ignition? I read the Lars faq about this but it says his procedure will not work on HEI ignition systems. Any good faqs for one with?
Thanks for any info.
Old Jan 25, 2006 | 09:42 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Your 72 should not have HEI as a stock ignition. Someone must have changed the distributor at one point.
Try this link to setup an HEI non computer controlled.
http://www.thirdgen.org/newdesign/tech/hei.shtml
Old Jan 25, 2006 | 10:38 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
thats a really good article, you know we all make this more complicated than it really is....once you have seen Lars do his magic to multiple cars you really start to realize this.
Old Jan 26, 2006 | 12:54 AM
comp's Avatar
comp
Old Jan 26, 2006 | 07:52 AM
7Deuce's Avatar
7Deuce
That's one of the articles I found last night while googling the subject. Glad to know it has good info. And yes, the HEI is not stock.
Old Jan 26, 2006 | 04:02 PM
Kalway's Avatar
Kalway
Just remember you want 36 degrees total advance.
Old Jan 26, 2006 | 04:42 PM
proracr's Avatar
proracr
The 71 that I bought last month has a HEI with mechanical tach drive on it. I haven't been able to "dial in" the advance on it yet. This article may help. Thanks!
BTW, at what RPM should we be getting 36 degrees advance?
Old Jan 26, 2006 | 04:54 PM
Eddie 70's Avatar
Eddie 70
It all depends on the springs that have been installed inside the distributor. Shoot for 36 degrees all in by 2500-3000RPM.
Old Jan 26, 2006 | 05:12 PM
flood's Avatar
flood
I just rebuilt my dizzy (kidtalk for distributor), I put in stock mech adv springs. I wonder how much effect different springs would have.
It seemed to run much better just getting the mechanical advance free again. it was rusted up.
To HEI ignition, checking timing
