I am installing an electronic dash that came with the 77 I bought several months ago and it has an Oil Temp gauge and no clock. I have a rebuilt small block in the car and figured that I could T off of the Oil Pressure connection, but I wondered if there was a better place to locate the sending unit for the Oil Temp.
Thanks,
Rob
The side of the oil pan about an inch off the bottom. Race cars drill a hole and weld a nut to the outside to thread it in.
I have a tranny temp sender. I just JBwelded it to the flat casting not far back of the dip stick tube. aluminum is such a good conducter of heat that it is probably within a few degrees of the actual oil temp.
When I checked my block (80-85) for oil pressure there was a port on the rear of the block (drivers side) on the intake manifold mounting surface. Would that work for an oil temp sensor?
When I added an oil temp. gauge, I moved the oil pressure sender to top of block & put the oil temp. sender by the oil filter.
Later I found out Corvette engineering agrees w/ me.
