Screeching noise
Old Jan 27, 2006 | 05:27 AM
enkeivette's Avatar
enkeivette
Default Screeching noise
There is some kind of screeching noise that comes and goes while I'm driving. Sounds like someone is rubbing a rusty nail on my rim. It seems to be independent of the brakes, when I apply them the screeching continues, until I come to a stop. And it sounds like it's coming from one of the rear wheels, not sure though. What could it be? Spindle, bearing related? Also, I don't know if this matters, but I disconnected the E-Brake a while back because it was in bad shape, made similar noises to what I'm hearing now. I removed the lever and the front cable but the brakes are still mounted back there. Not sure if this might have something to do with it. Thanks for any advice.
Old Jan 27, 2006 | 06:02 AM
bill bradford's Avatar
bill bradford
Sounds like your brakes pads might be worn. I would just take a look.
Bill.
Old Jan 27, 2006 | 06:24 AM
enkeivette's Avatar
enkeivette
That was my first thought, but the pads are still thick.
Old Jan 27, 2006 | 08:00 AM
DR.Jay's Avatar
DR.Jay
It sounds to me that the parking brake shoes inside the rear rotors are a good place to start. One of the retainer nails that hold the shoe may have come lose allowing a shoe to move around, and rub against the inside of the rotor.
Old Jan 27, 2006 | 08:03 AM
kb2fzq's Avatar
kb2fzq
Yup...sounds like...reconnect the e-brakes...maybe too late
Old Jan 27, 2006 | 11:06 AM
1970 Dave's Avatar
1970 Dave
Possibly could be my "gf" when she sees the UPS driver unloading more parts for the Vette
SEMPER FI--1970 Dave
Old Jan 27, 2006 | 01:17 PM
Eric79-L48's Avatar
Eric79-L48
My back left was rubbing something awful - put it on a lift, pulled the rear wheels, put it in gear and sure enough not only had the spring in the parking brake on the driver's side popped off but what was actually rubbing the inside of the rotor was this $.02 retainer/spacer that goes on the bolt between the two pads that keeps them inline. Anyway, replaced the spring, bent the spacer back to its proper position and case closed. All is well...
Of course, we had to stand on our heads to replace the spring without taking the thing apart, removing the back-plate, etc. but we were successful. Hope that helps!
Old Jan 27, 2006 | 01:29 PM
77 Vette Girl's Avatar
77 Vette Girl
Spring is broken or has come loose. Been there ..... Done that.
Old Jan 27, 2006 | 03:45 PM
Eric79-L48's Avatar
Eric79-L48
Yeah, crappy design if you ask me. But then again, what do I know.
Old Jan 28, 2006 | 06:00 AM
enkeivette's Avatar
enkeivette
Damn, always something... So then the rotors have to come off don't they? Is it true that I don't need to replace the rivets once I drill them out? I read that in my Chiltons manual.
Old Jan 28, 2006 | 08:06 AM
kb2fzq's Avatar
kb2fzq
Ah, yes....the privilege of owning an antique piece of beautiful art....
Could be worst, Hey, it'll keep ya busy for a day, get to work on your favorite car...just a thought, since you'll be in there, new parking brake shoes and while your at it, do the other side and that "probably" won't ever have to be done again...I do recall that the rivets can be left alone after drilling...have fun...good luck..
To Screeching noise
