Instrument cluster
Old Jan 27, 2006 | 11:00 AM
Clix ratchetelli's Avatar
Clix ratchetelli
Default Instrument cluster
I am working on a 1978 L82. My problem is all the gauges work fine until
I turn on the headlights, then the gauges peg, including the tach. Using the dimmer on the headlight switch causes the needles to swing like the dimmer is controlling the gauges. fuse does noy blow, I suspect that the power from the light cicuit is shorted to the gauges. Someone in the past has worked on this because the printed circuit board is chewed up.
I have the schematic from the service manual but it is not detailed enough to use it for circuit tracing also some of the nuts that secure the circuit board are missing.
What I need is a new circuit board and pictures of the back of the cluster showing which gauges receive the nuts before and then after the circuit board is installed.
Does anyone know a source for a reasonably priced printed circuit board?
Clix
Old Jan 27, 2006 | 11:17 AM
indy99's Avatar
indy99
From: the land of a never ending frame-off resto-mod. May Visa have mercy on my soul.
Ecklers, Mid america, Yogi Bairs, They all run close. About 80-90.00
Old Jan 28, 2006 | 01:49 AM
mstock's Avatar
mstock
Default Let us know
Let us know when you find out for sure what the problem was!
Old Jan 28, 2006 | 01:56 AM
zamika0a's Avatar
zamika0a
Are the all the light grounds installed properly? I had a similar problem and it turned out to be a loose tail light ground. Whenever I turned on the lights all my gages went nuts.
Good luck
To Instrument cluster
