Which intake gaskets?
Old Jan 27, 2006 | 05:36 PM
wes77's Avatar
wes77
Default Which intake gaskets?
I'm replacing my cam in 77 350 with crane H-272-2(wiped lobe xe-262). What Fel-pro intake gasket(1256,1205 or ?.) do you recommend with perfomer intake? Has anyone used Mr. Gasket cam change set gaskets?
Old Jan 27, 2006 | 05:41 PM
gerry72's Avatar
gerry72
Use the thick fiber gaskets. They're cheaper than the trick printoseal types and they work without any tricks. Just make sure you use a gasket adhesive around the bottom of the ports to be sure they don't distort.
