Lowering the front end
Old Jan 27, 2006 | 08:04 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Default Lowering the front end
Since I am replacing cast heads and intake with aluminum soon, I am expecting an already too high front end to be EVEN higher. Can I just cut a segment of the coil spring? If so, how much would you start with?
Old Jan 27, 2006 | 08:10 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
perfectly fine to cut some coils
start with a quarter coil at a time
I ended up taking out one and an 1/8th out of mine
i'll get some pictures up in a sec
Old Jan 27, 2006 | 08:15 PM
Corz's Avatar
Corz
Before, stock sb/ with ac springs (after yanking the ac)
after, with VBP 460lb springs with 1 1/8th coil cut
Old Jan 27, 2006 | 08:21 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Thanks Corz, I'll start with 1/2 coil, sound reasonable?
Old Jan 27, 2006 | 08:23 PM
Corz's Avatar
Corz
yeah, a half coil sounds about right.
good luck
Old Jan 27, 2006 | 08:29 PM
Lotus76's Avatar
Lotus76
Stock springs w/alum intake
550lbs springs
Old Jan 27, 2006 | 10:16 PM
copter's Avatar
copter
Please don't do this.It's what ricers do when they can't afford to do it right.Get a good set of coils that will lower your car and still retain the ride quality.
Old Jan 27, 2006 | 10:39 PM
rihwoods's Avatar
rihwoods
Guess I pre-date Ricers,cause I cut half coil off my stock FE7's and lowered it 1" 26 years ago....this is not a new idea and back in those days we did not have much mula to throw at these vettes...
Old Jan 27, 2006 | 11:14 PM
redvetracr's Avatar
redvetracr
Gee, according to YOU that would make me a ricer!! Hey Mr. Rocket scientist...what do you think racers (NO, NOT RICERS...RACERS) did before VB&P ?? They cut their springs....Plenty of guys here have cut their springs...me included!!
...redvetracr
Old Jan 28, 2006 | 01:13 AM
tfi racing's Avatar
tfi racing
Nothing wrong with cutting off half or a coil on a spring,just remember it also makes the spring stiffer as well as shorter.However,if you can spring for it,getting the proper rate and length spring is the best way to do it.
Old Jan 28, 2006 | 01:43 AM
Corz's Avatar
Corz
you callin me a ricer?
Old Jan 28, 2006 | 07:15 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
...redvetracr
Tell 'em Howard. Noobies..
1/2 coil sounds like a good place to start Brent. Here's a pic of the stock SB spring on the left and a new shorter replacement spring on the right. Cut from the bottom of the spring where the coil spacing is larger.
But in this picture I think they're upside down.
I still have my "cut" SB springs in and my "stance," ride & height hasn't changed much if at all.
Old Jan 28, 2006 | 07:53 AM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Old Jan 28, 2006 | 09:45 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
The 550 lbs springs are only $79 (and VBP offers a discount). I would rather spend that money than removing/cutting/reinstalling springs twice... chances that you get it right with the first cut are not very high... ask me how I know...
I do not recommend the 460 lbs springs, here's what my '79 looked like after I installed these (yes, the springs were seated correctly and the suspension settled):
Here's the same car with 550 lbs springs (nothing cut off the spring):
Old Jan 28, 2006 | 02:50 PM
copter's Avatar
copter
Gee,didn't mean to hit a sore spot with you guys,but I still stand on what I said.Do it right the first time.And yes I work in the Aerospace industry so I'm a lot closer to a rocket scientist than you think.I know what the racers did back in the day but we have other ways of doing this now.Those days are gone. Does this mean ya'all aren't going to talk to me anymore.
Old Jan 28, 2006 | 06:23 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
So, how much did it change the ride to go from stock to 460's to 550's? I like the look of the 550's but concerned about the ride?
Thanks!
Old Jan 28, 2006 | 07:37 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Thanks!
When your driving you don't really feel the front springs. You mostly feel the rear.
To Lowering the front end
Old Jan 28, 2006 | 08:22 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Thanks!
The 550s with the Bilstein shocks are simply awesome
I drove the car home after I bought it, that was the only time I drove with the stock suspension.
After I installed the 460s the ride was firm but not uncomfortable, I rebuilt the entire suspension so I cannot compare before/after.
There is not a huge difference between the 460s and 550s, except the ride height the 550s require better shocks (Bilstein or Koni) but it's really not too stiff.
Old Jan 28, 2006 | 11:41 PM
LFZ's Avatar
LFZ
just cut them until you get it right...you get good at it after a few times..i can take the wheels off, take both springs out, cut, put the springs back in, and both wheels on in less than a hour.
Old Jan 29, 2006 | 02:18 AM
Corz's Avatar
Corz
hell.. I did it without taking the wheels off..
