Ignition Switch Buzzer is Always On
What did I do wrong? If there's not easy fix, I'll probably pull the thing apart and hopefully, put it back together right this time.
Buzzer continues to operate with key removed, but stops when driver's door is closed:
There are three possibilities:
1. Chips, foreign material in lock cylinder bore.
2. Sticky lock cylinder actuator tip.
3. Damaged buzzer switch.
None of the above problems have anything to do with your ignition switch.
You can try "flushing" your lock cylinder with WD-40 or some other cleaner. This could clean out chips and possibly fix a sticky actuator tip.
The third possibility will require you to disassemble the steering column so that you can check the buzzer switch. I really isn't all that bad of a job.
Go to Terry Ruby's websight: http://www.bokonon.net/corvettefaq/ and look under Suspension and Steering. There is a paper on Buzzer Switch Diagnosis. There are two papers (with pictures) on disassembling the standard (non-adjustable) steering column or the T&T steering column.
If you have an early (1969 through 1976) T&T steering column you might have a problem in finding a new buzzer switch. You may need to obtain the paper on Where to Get Replacement Steering Column Parts also at Terry's websight.
Saginaw recommends using a small quantity of MOBIL 1 to lubricate the lock. Use a syringe or coat your key to get the lubricant into the moving parts.
Sorry about the bad info.
For those looking for the small plastic switch if you have the non tilt/tele column the switch is still available from GM. Us tilt/tele folks are in for a rude surprise since you have to go on the used market for these. This switch is nothing more than a clear plastic case with two thin copper strips in it. When you insert the key the two copper strips come into contact with each other and the buzzer goes off. BTW, these swithces are available from Corvette Steering Service although they are not cheap.
Gary
You should also look under Key Buzzer Diagnosis. The key buzzer switch is so simple you may be able to fix your original switch. Also the diagnostics will help you isolate exactly where the problem is.
