I replaced the fuel pump the other day and starter after that. both where shot. I fired it up last night and it purrrred. This moring I went to take it for a ride, no luck. The starter worked perfect and I checked the fuel pump, working perfect. The car without the air cleaner shot out a nice shot of gas through the carb. The car is turning over and I know gas is gettin in but no engine running. Any ideas as to how I screwed this up? Thanks
This is very weird...I seem to see this alot..."ran great, shut it off, doesn't run next go around"...I agree it sounds like ignition, but ya didn't touch the ignition parts...right?
Very weird...see if ya got spark at the coil wire to start...then at the plug..
Not sure about your car but many cars, mine included, had an ignition wire attached to the starter. It provided full battery voltage to the coil while cranking bypassing the ballast resistor. If you have this style set up maybe the wire on the starter is the problem?
Thanks for the info. I've checked all these ideas. This morning I went to crank it again. Its still turning over and after a couple of seconds the engine almost ignitites for a second then just keeps turning over then almost ignitites again. Its trying but something just aint working to get it that kick to get it going. Still trying though.
Ah the good ole burn the points myth, more important is you would drain yor battery.
The points are just an on/off switch to energize and de-energize the windings of the coil. When the points open the magnetic field of the field windings colapses and created the spark.
This is much like an electric solenoid, except instead of the metal core which produces the magnetic force to operate whatever the solenoid is operating.
That being explained, the duration of contact or open, does not matter in the "burning" of points (much like relay contacts). If points "burn" it is usualy because they were already bad and needed changing. When points are somewhat bad, they are not making a "full" connection and resistance builds which can cause heat.
Dirt can cause an improper contact also and expidite the premature failure of the contact area with arc-ing at each open and close of the contact.
Coil replacement with High energy coils can exasperate the points also.
Points replacement is one of the cheaper ways to keep your engine running well
VERY GOOD, mag00!! I've tried to explain this theory to many friends, only to receive that "blank stare" back at me
Gotta copy that and forward
As far as the problem, I still find it hard to believe that it ran great, off, won't start...unless a fusy link or fuse popped during the re-start..I still stay with checking for spark on the coil wire at the distributor while cranking..that will tell if it's a flood problem or a spark problem...don't think I saw a reply on that...
