Rear main seal
Old Jan 30, 2006 | 08:17 AM
7t6vette's Avatar
7t6vette
Default Rear main seal
I have a 383 stroker in my vette and I'm in the process of replacing the rear main seal. What I don't know is if I should get one for a standard 350 engine or will it be a different size.
Old Jan 30, 2006 | 08:19 AM
GDaina's Avatar
GDaina
Should be for a 400 sb crank
Old Jan 30, 2006 | 08:28 AM
Gordonm's Avatar
Gordonm
I don't usually disagree but you want one for a 350 crank. The 400 crank mains are a different size. If you are using a 350 block the mains are smaler than the 400. If you use a stock 400 crank you have to turn down the mains. If it is an aftermarket crank it already has the smaller mains.
Old Jan 30, 2006 | 08:32 AM
GDaina's Avatar
GDaina
Ahhhh...thanks...I guess I'm stuck in the 70's cause that's what guys did, grind down the mains on the 400 crank.
To Rear main seal
