Wheel Well Clearance
Old Jan 30, 2006 | 09:16 AM
BIGJIM13's Avatar
BIGJIM13
Default Wheel Well Clearance
HI
On a 74,
How big should the gap be between the frame and the body back at the passenger rear wheel - where you can see the fuel lines!
We just put the body back on !
Old Jan 30, 2006 | 01:00 PM
BIGJIM13's Avatar
BIGJIM13
HI
If someone could just have a look in their rear wheel well and give a guess as to clearance between the frame and body where the fuel lines set - that would probable help, 70s or 80s cars
Old Jan 31, 2006 | 02:44 PM
BIGJIM13's Avatar
BIGJIM13
HI
Old Jan 31, 2006 | 11:18 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
I don't have a 70's or 80's C3 but the measurement on my 68 (right above the rear bumpstop) is 1.200 inches. The rubber mount cars are supposed to sit up higher. I've heard 3/8 inch or more. Hope this helps.
Old Feb 1, 2006 | 03:19 PM
427basketcase's Avatar
427basketcase
I looked on my 69, there is @ 1 inch, and yes you can see the fuel line.
Old Feb 2, 2006 | 12:29 PM
BIGJIM13's Avatar
BIGJIM13
so if mine is setting at about 2" - there apears to be a problem!
Old Feb 2, 2006 | 01:59 PM
BBShark's Avatar
BBShark
I think almost 2" is right. Like I said my 68 solid mount car is 1.20. If you add the additional height of the later rubber mounts (and the mounts are not bolted/compressed), you might be correct at 2".
To Wheel Well Clearance
