Distributor vs. Distributor
Old Jan 30, 2006 | 09:02 PM
kdcollins's Avatar
kdcollins
Default Distributor vs. Distributor
Good evening all.
I am slowly gathering the parts needed for the installation of my new blower and including in my search are distributors. I have learned the HEI is not going to fit with this blower. With this being said, what would be a decent distributor for use with my setup?
355 ci
8.3:1 cr forged pistons
2.02 int - 1.6 exh / 64cc aluminum heads w/200 cc runners
.464 int/.464 exh lift, .222 int./.226 exh. dur @.050 - 114* lobe sep.
full roller rockers
671 blower
2 - 600 Holleys
4 speed
I seriously doubt the engine will ever see 6000 rpm's, just a Saturday night cruiser for the Mrs and myself when we want to go get a sody pop.
I would certainly welcome any recommendations and explanations.
Thanks!
KC
Old Jan 31, 2006 | 08:15 AM
Hvymtlc5's Avatar
Hvymtlc5
Mallory Uni lite uses a very small cap that may give you the clearance you need.
http://www.centuryperformance.com/ma...zzymatrix2.asp
Old Jan 31, 2006 | 11:35 AM
MIKER's Avatar
MIKER
Maybe the small cap Crane Street/Race Distributor would fit.
Crane optical trigger Street/Race Distributor w/27 selectable advance curves.
http://www.cranecams.com/?show=promo&id=16
HI-6 Performance CD Ignition
http://www.cranecams.com/?show=brows...30&showAll=yes
TRC-2 Timing Retard Control
http://www.cranecams.com/index.php?s...lvl=4&prt=2011
Old Jan 31, 2006 | 11:40 AM
tigers123's Avatar
tigers123
Default small is the key word
This guy makes Hei distributors in a compact form
http://www.davessmallbodyheis.com/
Don't know anymore about them , other than what you see on his website.
Old Jan 31, 2006 | 12:52 PM
norvalwilhelm's Avatar
norvalwilhelm
I run a mallory with it's small cap and unilite pickup. Other then that I run a Accel coil and 4 msd boxes
Old Jan 31, 2006 | 01:33 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Hey Kevin,
If you are going to run an ignition box, I would look into the like brand of distributor for a "plug and play" type situation.
Also Crane makes a nice ign. box with timing retard control built in. Something you may want to consider.
If you are not concerned with tach drive capabilty you'll have a large selection of distributors to choose from.
Old Jan 31, 2006 | 08:40 PM
73 Vet's Avatar
73 Vet
I've got a BB w/8-71 and am using the MSD Pro-Billet Mechanical tach. drive. Fits fine.
Old Jan 31, 2006 | 09:24 PM
kdcollins's Avatar
kdcollins
Thanks for all of the input!! I have done a little looking around with your suggestions and I think I may have one picked out. Maybe.
KC
To Distributor vs. Distributor
