Help! 74 Headlights Stuck Open
http://www.corvette-101.com/
Hope this helps.
If they've been working okay you probably do have a vacuum issue though.
good luck
if that isn't the case, you can reach under the headlights and pull the buckets down manually (do it with the engine NOT running). once they are down, you can see if they might work going up again. if they do, you at least are getting vacuum from the manifold through the check valve and filter, throught the headlight switch and over ride switch and through the vacuum relay(s). if you have a vette with a windshield wiper "door" that is vacuum activated, you will have one relay at the wipers and one relay mounted between the headlamps under the nose section infront of the hood opening. if you have a "fixed" hood and regular wipers, you will have 2 vacuum relays both mounted under the nose, 1 each for each side of the headlamps.
the most common problems is that the seals in the actuators ("cans") start to leak. that will bring the entire system to it's knees. they can be inspected by removing the grills and pulling back the dust boot on the actuator arm that is connected to the headlight mechanism to expose the seals. if necessary, they can be changed without removing the actuator from the car, you simply need to disconnect the rod end clevis and you can get to the seals. with the hood open and the engin running, have someone ativate the headlight system (pull the headlight switch on) and see if you can't hear anything "hissing". if you can try to find it because that is more than likely a source of you problem. your car is 71 and newer, so you have a log type vacuum tank behind the radiator on the frame. they tend to be a bit more durable and unless damage by accident, rarely fail on their own (unlike the earlier version mounted inside the driver's side fender.
just a suggestion, but a complete kit to replace the vacuum hoses in the system can be had from doc rebuild for around $50.00 including s detailed diagram of the hose system. you can physically check the check valve by attempting to blow backwards through it. if you can, it is bad and is letting vacuum leack backwards through the system. fortunately, all the parts ou might need are readily available.
i hope that helps you out some and provides some direction.
