Air Cleaner
Old Jan 31, 2006 | 12:04 PM
D87's Avatar
D87
5th Gear
Default Air Cleaner
Which Air Cleaner Base Seems To Work Best
Just Installed 385 Fast Burn Engine With Edelbrock
Carburetor In 1980
Having Problems With Hood Clearance
Old Jan 31, 2006 | 12:42 PM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
Generally a 1.5" to 2" drop base cleaner will help alleviate the issues you are having. I happen to be running a Moroso Low profile racing air cleaner, and am considering going to even more drop to get the clearance I need.
trw
Old Jan 31, 2006 | 01:38 PM
jimmygmartin's Avatar
jimmygmartin
The air cleaners from the early C3's work well. I am still using the original on my 68 with a 383. The vent tube needs to be removed and plugged if you are running a double pumper. I used a simple rubber expansion plug.
To Air Cleaner
