Yoke Gaps?
Old Jan 31, 2006 | 03:52 PM
Vesa's Avatar
Vesa
Default Yoke Gaps?
I have 1973 Vette with U-bolt style yokes (Standard). I was thinking of
replacing the U-bolts with those (HD style) gaps that are used in the HD
yokes. Are these Gaps direct fit to U-bolts style jokes? Then I just would need to get longer (and strong) bolts + nuts from hardware store...
Anyone tried this?
Old Jan 31, 2006 | 04:59 PM
GTR1999's Avatar
GTR1999
The "HD" yokes are tapped 3/8-16 the std yokes are drilled out for the U-bolt to fit. You'll have to swap yokes. If they have less then .040" endplay don't bother until you need to.
Old Feb 1, 2006 | 12:10 AM
Vesa's Avatar
Vesa
I know that, but what if I just put the GAPs on a std joke and buy long enough bolts so that they come out from the jokes U-bolt holes and put a nut there to tighten the assembly??? The question is more like if the GAPs fit tight on to the STD yokes and do tighten the U-joint properly???
How do you measure a endplay, between which surfaces and how?
Are the STD yokes with U-bolt kit strong enough for 500hp BB with 4.11 rear end gears? That I a bit doubt...
Old Feb 1, 2006 | 01:20 AM
Vesa's Avatar
Vesa
...about the endplay...I do have the dial gauge with magnetic base that I use for measuring the backlash between pinion and ring gear - can I use this gauge somehow to measure the endplay?
Old Feb 1, 2006 | 06:36 AM
RHD '68 L89's Avatar
RHD '68 L89
I think you mean Yoke Caps not gaps. As Gary said, the factory HD caps are tapped for the bolts. You may be able to use longer bolts with nuts but I don't think the HD caps will match the standard yokes.
EDIT:
I re read Gary's post and maybe they are the same yokes.
Old Feb 1, 2006 | 07:16 AM
Vesa's Avatar
Vesa
EDIT:
Sorry my bad english - yes Caps I mean!!!
Yes that I was thinking that maybe GM first used only Standard ones with U-bolts but when powerfull BBs came (L-88 etc...) they started to break and they started to call them HD by replacing the U-bolt with Caps and individual bolts...
Old Feb 1, 2006 | 09:54 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
The hole spread is different from the u-bolt style to the BB style. If you tap the u-bolt style, the holes on the caps will not line up.
Old Feb 1, 2006 | 10:39 AM
Vesa's Avatar
Vesa
I see - you mean that the distance between the 2 holes in a Cap is different from the distance between the 2 holes in a U-bolt style yoke. Then it is a no go...
Thanks for the info!!!
Old Feb 1, 2006 | 01:17 PM
Van Steel's Avatar
Van Steel
yep
Old Feb 1, 2006 | 05:30 PM
GTR1999's Avatar
GTR1999
Of course,depending on your access to a machine shop, you might be able to machine caps and tap the yokes for a larger bolt. I haven't done this, as I just swap the yokes when changing from one to the other but maybe parts are harder for you to get over there?
Old Feb 2, 2006 | 08:19 AM
Van Steel's Avatar
Van Steel
We thought about offering that but it doesn't look like there would be enough meat on the cap if the hole is moved out any further.
To Yoke Gaps?
