Rad support question
Old Jan 31, 2006 | 08:20 PM
1mollyd's Avatar
1mollyd
Default Rad support question
When I pulled the rad support on my '69 coupe I found that it was somewhat rotten on the bottom.
So I hunted around and found a replacement unit. However, when I pulled the original rad support out it had shimms under it where it bolted to the frame on the bottom.
My question is: If it needs to be shimmed, what should I shim it to? How do you tell how many shims? Is there a measurement I need to shim to?
Sorry, that was 3 questions.
TIA
Dave
Old Jan 31, 2006 | 10:22 PM
rponfick's Avatar
rponfick
I just shimmed mine enough to lift up the nose slightly with the center support rod and have the hood line up as good as possible.
