Wiper Switch MisAlignment
Old Feb 1, 2006 | 12:09 AM
kaiserbud's Avatar
kaiserbud
Default Wiper Switch MisAlignment
The Wiper Switch does not align properly - I do not see any way it can be adjusted. Has anyone else encountered this? In this picture, I am using a broken switch - rather than having the larger 25 cent size head, the remaining shaft has just a piece of the old head sticking out. The bracket does not look bent. It is basically has 90 degree bends in it.
Old Feb 1, 2006 | 12:31 AM
kaiserbud's Avatar
kaiserbud
I just went out to the garage to check the bracket - now that I have it out and can take a good look at it - it is a tad out of shape. The angle to the mounting surface is tilted slightly away from the bolt holes and that may make it sag 1/8". Between the upper 2 bends - there is possibly another 1/8". Will check the catalogs tonight to see how much they are - or whether I will be bending them back into shape.
Old Feb 1, 2006 | 12:35 AM
Z-man's Avatar
Z-man
It's hard to tell. Can you do any adjustment if you loosen the two bolts in the picture??
Old Feb 1, 2006 | 07:59 AM
kaiserbud's Avatar
kaiserbud
Those are at the top too.
To Wiper Switch MisAlignment
