I use Mr. Gasket Ultraseal gaskets with my cast aluminum covers and ARP studs. The Ultraseals are cork gaskets with a non-stick coating so they don't tear when removing the valve covers.
Never had a need to glue the gaskets. No leaks and I can remove the valve covers easily.
Rubber here on my 72 BB, although the Mr Gasket Ultraseal cork / non stick coating combo sounds good also. Never had much luck with plain cork on my 67 BB, always seemed to leak at lower rear of passenger side.
I have removed mine at least 5 time. No leaks either.
Cork will harden and crack with age. At least that's what the one's in my 68 did until I eventually replaced them with rubber/neoprene. Once the cork gaskets crack, they leak oil and the resulting oil leaks do an excellent job preserving the engine compartment and underneath of the car. When I eventually cleaned off the accumulated oil and dirt, the parts underneath all the gunk, looked like the day they came off the assembly line.
