Replacing door parts Help!
Old Feb 3, 2006 | 12:29 PM
bluesilver82's Avatar
bluesilver82
Default Replacing door parts Help!
82 vette, I need to tighten the windows, repair door locking and exterior handle mechanism as well as replace the power door lock actuator. How do I get inside the door? I took the interior door panel off and the only way I saw is the access panel that supports the power window actuator. Do I have to try and work throught this little opening at the bottom of the door or is there another way to access the items I need to repair? Does the interior Metal door skin come off some how?
Old Feb 3, 2006 | 02:49 PM
79vetter's Avatar
79vetter
I just got done taking locks, door handle, windows and guides out of my '79. Not sure if yours if different. But if you are wanting to take all of this out and clean it like me then you should take out the glass first.- makes things easier to get to. The access panel that you are speaking of will need to come off so that you can get hands manuevered around. Really not a bad job- removing the glass - when done with another person is not bad either. I used the service manual as well. Let me know if I can help.
Rob
