Replacing side mirror
Old Feb 3, 2006 | 03:06 PM
bdr922's Avatar
bdr922
Default Replacing side mirror
I have a 71 coupe and the previous owner replaced the side mirrors with the 80's sports mirrors. I am going to try to change them back to the original mirrors (on both sides). I am also replacing my door panels and want to get it done at the same time. Does anyone know if there is any trick to taking off the current mirrors, and then puting on the new chrome ones? Do I take them off from the inside of the door? I ordered all the hardware that I'm told I need.
Old Feb 3, 2006 | 04:36 PM
bluesilver82's Avatar
bluesilver82
Not quite sure but I think they unbolt form the inside (thinking back to my days with a 72). I am attemting to get in the doors of my 82 and it does not lock easy. I have some lock and latch issues. I was told to remove the window glass. It gives you more room to work. Good luck!
Old Feb 3, 2006 | 04:44 PM
Todbo's Avatar
Todbo
71' would attach from the outside - no door panel removal req- but i have no idea how they attached the 80' or better yet how to remove them
Old Feb 3, 2006 | 04:47 PM
70454's Avatar
70454
Correct. There is an allen wrench fitting on the underside of the mirror. No need to take out window or even look inside car.
Old Feb 3, 2006 | 11:02 PM
bdr922's Avatar
bdr922
There are no allen wrench screws on the sports mirrors...any ideas how to get these things off?
Old Feb 3, 2006 | 11:06 PM
icanfixitforyou's Avatar
icanfixitforyou
O.K. Take off the interior door panels - that will give you access to the underside of the door skin, roll the window up out of the way and see what kind of fasteners your "custom installed" mirrors have.
Old Feb 3, 2006 | 11:43 PM
David Ey's Avatar
David Ey
bdr922, if you have the remote bezel that goes on the driver door panel I'd like to talk to you about purchasing it.
Thats correct, you must remove the door panel.
Old Feb 4, 2006 | 08:02 AM
C3 4ME's Avatar
C3 4ME
The mirrors on the late 70's early 80s cars are bolted on from inside the door, and the glass has to come out to get to the nuts. I just took them off last weekend on my 79 along with the trim, handle and lock cylinder on my doors in preparation for paint. (I hope someone doesn't come back with an easier way and make me feel like a fool for all that work!)
Old Feb 4, 2006 | 01:56 PM
BKbroiler's Avatar
BKbroiler
In order to remove the sport mirrors on my 77, I had to remove the door glass. I have a shop manual, that helps.
To Replacing side mirror
