'72 BB headers?
Old Feb 16, 2006 | 04:47 PM
norvalwilhelm's Avatar
norvalwilhelm
Originally Posted by MEGALADON
Norval, are those the $169.00 heddmans headers you got wrapped
up?? They don't look like long tubes
Yes they are the long tube headers. Other then the ball on the end they are exactly like my old set. At $169 I feel they are a good deal and consumable. As for fit they seem to drop right in. Never an issue with installing them. Takes only a few minutes to get them installed with the end bolts.
Old Feb 16, 2006 | 05:10 PM
ZO SIC's Avatar
ZO SIC
Can yo post some pic's??
Will work on it... any specific areas?
I did re-use the front stud on the drivers side for the alt bracket, but had to space it out with 3 or 4 washers, which may have thrown off the angle of the alt pulley/belt. If I have issues I will remove that stud, grind some off and re-install.
I removed the AC compressor to do the manifold removeal and install the headers and since it didn't work anyways, now is a good time to send it off to have it rebuilt.
Now I guess I'll have to modify the AC bracket that attaches to the two manifold studs and probably have to grind them down as well... but that is in the future.
I thought there was no pressure in the AC system, but when I unbolted the AC lines from the compressor it did let out a 5 second hiss. If I do rebuild the AC system I'd like to get new lines, but last I heard no-one makes them for a '72 BB Corvette. So maybe I can get a shop to put new lines onto my fittings? I do have a spare AC line that has ruptured hoses that I could use first. Doesn't look like fun to R&R that sucker though.
Old Feb 16, 2006 | 05:26 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
You can start with the headers. and Part #
Old Feb 16, 2006 | 05:30 PM
ZO SIC's Avatar
ZO SIC
Unfortunatly I didn't snap any pics of them out of the car... They came painted black and I had them blasted and coated in a flat black cermaic coat locally for $259.
I'll get pics up later...
Hooker are $473 from Summit for the PN-2123HKR (1.875" and 3") (uncoated)
Old Feb 16, 2006 | 05:40 PM
MEGALADON's Avatar
MEGALADON
I would like to see them installed on the car.
Old Feb 17, 2006 | 12:14 AM
Simmo's Avatar
Simmo
Originally Posted by pmazza
Another option for BB Corvettes is Thorley #THY-360. 14 guage, 3/8" flange, 2" primaries all 34-36" length. These are better quality than any SuperComps I have used in my other cars.
Will only fit manual trans, no AC cars due to equal length tube routing. I special ordered through Summit a long time ago, cost was @$330 uncoated.
Phil
Ive got these in my 70. Well made.
