Strange voltage surges
Old Feb 5, 2006 | 10:46 PM
JB's Avatar
JB
St. Jude Contributor
Default Strange voltage surges
Electrical stuff is still a great mystery to me, I'm ashamed to admit, so I'm hoping one of you can fill me in about something. Recently, when I'm going down the road at night at a constant speed, the headlights and dashlights will suddenly get very bright for a few seconds, and the voltmeter jumps way up. It will do this a couple of times a minute for a while, and then stop for five or ten minutes, then start doing it again. Can anyone tell me what's going on?
JB
Old Feb 5, 2006 | 10:50 PM
s car go's Avatar
s car go
Your voltage regulator is NFG. If its inside the alternator replace the entire alternator.
Old Feb 5, 2006 | 10:53 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Bingo..
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you have a voltage sensing circuit that adjusts the alternator output based on the load the sensing circuit percieves....so something is up, either in your wiring or in your alternator
Old Feb 5, 2006 | 11:06 PM
Richard454's Avatar
Richard454
It's the voltage regulator - I'd replace it ASAP-otherwise you be burning up bulbs-radio etc.
Richard
Old Feb 5, 2006 | 11:56 PM
SIXFOOTER's Avatar
SIXFOOTER
Yep, its the VR. It sences battery voltage and used that to bias down the alternator when the batt voltage goes up (charged), when batt voltage goes down it runs the volys up on the regulator. If for some reason it loses the battery voltage totally, the alternator voltage goes way up, folowing RPMs.
I got a ride home in the dark once because of this
Old Feb 6, 2006 | 12:06 AM
JB's Avatar
JB
OK, cool enough. Thanks, guys. 'Nother question: I've got the internal voltage reg--is it really necessary to replace the whole alternator or is it possible to replace the regulator?
JB
Old Feb 6, 2006 | 06:27 AM
kb2fzq's Avatar
kb2fzq
Richard
Absolutely...do it soon, and don't start it until it's been replaced
Old Feb 6, 2006 | 10:20 AM
SIXFOOTER's Avatar
SIXFOOTER
Sure you can do that, I got mine at a shop in boynton beach that does auto electric only, the guy had all the parts and pieces I needed, took me about 2 hrs start to finish.
To Strange voltage surges
