Am installing a 454 in my '69 coupe and want to consider sidepipes. From previous threads, I understand a 3 inch standard exhaust can be run to the rear. Can I assume a chambered exhaust is the only way to quiet down the car or is there a true 3 inch standard muffler available somewhere? Then, of course, there is the issue of the tips. I don't see three inch tips coming out through the fiberglass easily. Seems like sidepipes are less a challenge. Any input would be appreciated.
I am not a fan of side pipes. They dump the exhuast right beside your ear. YOur hearing is worth more then a set of side pipes. I found with side pipes I had problems talking on the phone for a few days after a hard run. I dumped them quickly
Besides if you want mufflers at all they are too restirctive.
I feel a complete exhuast is less restrictive then side pipes.
There are lots of honest 3 inch mufflers on the market.
I run a full 3 inch exhuast front to rear with 3 inch mufflers and you can outrun the exhuast when driving on the expressways.
As for tips a pair of 3 inch down pipes works great.
I have litterly hundreds of 3 inch aluminum down pipes and yes you can use aluminum for down pipes.
If you go that route I will sent you a pair.
The guys who have said they've installed the spiral mufflers in their sidepipes say they run as quiet or quieter than the stock exhaust. I don't know how much of a flow restriction they are, but looking at them it can't be too bad.
I'm looking first for best flow for hp. Second, for the a moderate sound because I drive this car a lot (20,000 miles a year, mostly highway), and third, longevity. Sounds like jet hot can give me the third, but a compromise between moderate sound with little restriction seems to be a real challenge. Has anyone else found a solution?
I also prefer a full exhaust. The side pipes are easy to get burnt on getting in and out of the car. They do sound good when you are trying to sound good, but when you are just crusing trying to be mellow your still have the loud side pipes.
If you're going to be driving that much, I personally would not recommend sidepipes. Go with big fat duals to the back. You're going to end up with burnt calves and broken ear drums, if you do.
Performance wise, a 3.5" spiral muffler is pretty dang good, I dae say as good as any under car system. There is almost no restriction in a spiral muffler.
Noise, yes they are louder than an under car system. but the wind noise at 70MPH is louder than the side pipes on my 460hp small block 434. So I don't see it as an issue.
I also run the 3.5" muffers under fiberglass side pipe covers. They barely get warm...
Ya know... even with straight headers, going down the freeway wasn't that bad... If you want to spend the extra $$$ and do a really good sidepipe job it's worth it. However, they'll never be as "comfortable" as rear exhaust. Also, remember you lose a lot of ground clearance with side pipes.
Im gonna start wearing ear plugs when I drive my car with sidepipes. Id rather buy earplugs than put in mufflers. Its rarely drvin on the street anyways.
If you just want to look and sound bad ***, it's really hard to beat sidepipes. Hence why I put mine on.
But what is your hearing worth> YOU guys are young and think you will worry about it down the road., Too late. Protect your hearing now. If you run quiet mufflers in the side pipes you are still sitting over the outlet and regardless of the noise you are hurting your ears.
A good under car exhuast is far better.
Gee whizz, no one has called me "young" for thirty years; sounds good. I'm thinking at my age the opportunity for sidepipes (remember when we called them lakers?) is on the last go-around with this rebuild. I agree with a previous comment that wind noise at 60 to 75 is often just as noisy as anything. And I appreciate the info on Stahler; will go looking for them--any idea where? Am hoping to stay at 3 inch instead of four if possible. Forgot to mention I'll have a Keisler 5 speed so rpm at cruising will be reduced from the mid 30s to around 2000, so that ought to help. Someone also mentioned shields--have yet to see any aftermarket applications except for factory fiberglass reproductions. Anyone got a lead where to find those as well? Someone told me I'd burn my leg only once without them...
I'm all ears on this topic.
At the same in-cabin decibel level, any potential hearing effects will be identical, no matter where the outlets are located. My 77 makes so much noise from the engine, wind, body squeaks, etc. that I doubt sidepipes with mufflers will hurt anything.
No way do you lose ground clearance with sidepipes. In fact you gain significant clearance, especially if consideringa 3 inch undercar system. I have had em all on my car and the Hooker sidepipes offer the best case as far as ground clearance goes, hands down.
