Metallic tapping noise from engine
Old Feb 6, 2006 | 11:47 AM
zwede's Avatar
zwede
Default Metallic tapping noise from engine
Engine: Mark IV 454 with mods as per sig. Daily driver. 50K miles since rebuild.
For about a week now it has made a tapping noise after it fully warms up. There is no noise at all when cold.
Noise is coming from underneath the engine. I think more drivers side than passenger, but not sure. Noise is almost inaudible from the top. I put a hose to the valve covers and listened and there is no noise from the valve covers.
The noise is not coming from the front of the engine.
I revved the engine in neutral and let off but didn't hear the tell tale loud tapping as the engine slows down that I've come to associate with a spun rod bearing.
I checked for exhaust leaks and couldn't find any. I've had exhaust leaks before and this doesn't sound like one anyway. It has a sharper note to it.
Any ideas? Bearings? Oil pump? Oil pressure is the same as it has always been: 40 PSI hot idle, ~55 PSI going down the road.
I'm thinking I'll throw a set of rod bearings at it but might just be wasting my time?
Old Feb 6, 2006 | 12:27 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
i've had trouble in the past with the TRW forged piston with the long oiling slot. Due to improper clearance the skirt would break off but continue to move up and down with the piston. It makes more of a clacking sound rather than a knocking. I drove myself nuts trying to figure it out replacing cam, lifters and rod bearings. I hope that's not what it is because it means a total rebuild.
Are you sure its not a lifter or fuel pump pushrod?
Do you have an engine stethescope to try and pinpoint the noise?
Old Feb 6, 2006 | 12:38 PM
zwede's Avatar
zwede
Not sure about anything. Just guessing at this point.
I need to pick up a stethoscope.
Electric fuel pump, so that's out. Unknown pistons, but I'm pretty sure not forged. Stock style rebuild done by previous owner. Probably cast or hyper pistons.
Could be a lifter but I expected to hear noise from the valve covers.
Old Feb 6, 2006 | 12:44 PM
rihwoods's Avatar
rihwoods
Many years ago I picked up a similar noise at an autocross...we all thought it was bearings...dropped pan and everything was cool...bottoned it up and someone suggested carbon...which normally comes higher in engine(sound)(we were confused where).. So we misted water down carb at 1500-2000 RPM...noise went away..Suggest you give that a shot...also,listen at pan,lower block with hose if you can get it on ramps...let someone rev it for you....
Rich
Old Feb 6, 2006 | 02:10 PM
zwede's Avatar
zwede
I'll pick up a stethoscope and listen at the oil pan. I guess carbon is a possibility.
Old Feb 6, 2006 | 02:22 PM
pef427's Avatar
pef427
I had an old 4x4 with a 454 that did this. It turned out to be a wrist pin. Fix it soon...BG CF Cruise-In is coming.
comp's Avatar
comp
good luck
Old Feb 6, 2006 | 02:38 PM
zwede's Avatar
zwede
Just went out in the parking lot and dribbled a cup of water into it. Seems to runa little smoother but the noise is unchanged.
Didn't want to hear about the wrist pin.
TedH's Avatar
TedH
Recently found my pushrods with the ends that are pressed/welded in had a few loose ends that contributed to a noisy valvetrain. Previously eliminated potential exhaust leaks, cam wear, defective lifters, rockers, springs etc.
Replaced with hardened one-piece pushrods on left bank and sound decreased significantly. Replacing right ban of pushrods next week.
Old Feb 6, 2006 | 02:44 PM
Ganey's Avatar
Ganey
Any ideas?
1 Disconnect spark plug wire one cyl. at a time w/ engine running, listen for the noise to change.
2 Listen at flywheel area.
Old Feb 6, 2006 | 03:08 PM
zwede's Avatar
zwede
Good point. I'll do this tonight.
Old Feb 6, 2006 | 06:18 PM
BigBlockk's Avatar
BigBlockk
You may want to hook a timing light to each plug to try to narrow it down to one cylinder.
BigBlockk
Later.....
Old Feb 6, 2006 | 07:12 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Had the VERY SAME thing happen to me....check out my thread and the responses I revceived.
http://forums.corvetteforum.com/show...y75&forum_id=3
The only thing left to replace, for me, is the crankshaft & bearings. Took it into Red River Chevy today to have the engine pulled & new crank with bearings (SCAT Performance Steel Crank) installed.
Good Luck!
Old Feb 7, 2006 | 08:08 PM
zwede's Avatar
zwede
Problem solved and it turned out to be rather silly. All it was, was a wire rattling against the firewall metal heatshield. Tied everything up with some zip ties and no more noise. Surprised me it could be loud enough to hear inside the car with windows up.
Old Feb 7, 2006 | 08:12 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Thats good news !!
Old Feb 7, 2006 | 08:52 PM
rihwoods's Avatar
rihwoods
Bet you are relieved...
Rich
Old Feb 7, 2006 | 08:57 PM
GDaina's Avatar
GDaina
You don't need one....you have one in your tool box....a long extension..
To Metallic tapping noise from engine
Old Feb 7, 2006 | 09:31 PM
zwede's Avatar
zwede
Rich
You betcha. And when I got home I had an email that my Wilwood brakes have shipped. Woohoo!
Old Feb 7, 2006 | 09:35 PM
GDaina's Avatar
GDaina
Now you can work on the 632 without worries about yours
Old Feb 7, 2006 | 09:37 PM
goinbroke's Avatar
goinbroke
Glad it was nothing serious Markus.....I had my fingers crossed for you.
