Hazard Switch Replacement
Old Feb 7, 2006 | 12:04 PM
MAZ73's Avatar
MAZ73
Default Hazard Switch Replacement
Anyone have a repair manual or link on replacing the hazard light switch on a 73?
Old Feb 7, 2006 | 01:02 PM
Vette Gator's Avatar
Vette Gator
There isn't a separate hazard switch (at least on a 76, and I'm pretty sure it's true for yours as well). The hazard **** attaches to the side of the turn signal switch via a stamped metal part about 5" long. I found this piece lodged down in my steering column when I was changing the turn signal switch. I pulled the wiring harness up and it fell into my lap.
Old Feb 7, 2006 | 01:54 PM
Jim Shea's Avatar
Jim Shea
The turn signal switch has the hazard warning circuit switch integrated into it. You push directly on the switch if you have a standard (non-adjustable) column.
As mentioned above, if you have a T&T column, there is a stamped lever about 5 inches long that inserts into a slot on the underside of the turn signal switch and activates the hazard circuit. The other end extends down and pivots inside the column head. The T&T hazard **** screws into a tapped hole about half way down the lever.
To replace the switch, you need to remove the steering wheel and disassemble the upper end of the steering column. Here is a link to a listing of a number of my C3 steering papers that are hosted at Terry Rudy's Corvettefaq.com websight.
http://jimshea.corvettefaq.com/?page_id=4
Scroll down to either Std Columns or the T&T Columns sections depending on what type you have.
Click on the link and download Paper #1 and Paper #2 as well as Pic #1 for your column. You will find that the papers include very complete instructions on replacing the turn signal switch.
Good luck,
Jim
Old Feb 8, 2006 | 07:40 AM
MAZ73's Avatar
MAZ73
Thanks Jim, I'll have a look and see where to go from here.
To Hazard Switch Replacement
