Engine choice
Old Feb 7, 2006 | 10:59 PM
JustForFun's Avatar
JustForFun
Default Engine choice
Heres the engine im thinking of ordering for my 81 http://www.gmpartsdirect.com/results...umber=12499529
question i have is how compatible with TPI will this engine be? If its "too much" engine, could one of you suggest something little closer to what i need. Im not making this car a racer, nor do i care alot about performance. Im just creating a weekend driver
Old Feb 7, 2006 | 11:05 PM
big_G's Avatar
big_G
Definately not too much engine. Should be about the same as what you are running now (stock).
Old Feb 7, 2006 | 11:07 PM
JustForFun's Avatar
JustForFun
i mainly was wondering if the cam in that one would be too much for stock TPI system
Old Feb 7, 2006 | 11:13 PM
fl_rider's Avatar
fl_rider
I have just over 6000 miles on my GMPP 350/290. It is a solid running engine. It's no rocket but its no dog either.
This engine would work fine with TPI.
big_G's Avatar
big_G
The power peak is at 5,100 rpm, which matches tuned-port nicely..(tuned-port engines start wheezing at about 5,300). The cam specs would probably be close. The only thing that bothers me is the note at the bottom of the description that states "not for use with fuel injection". You might call them and ask about that.
Old Feb 7, 2006 | 11:15 PM
JustForFun's Avatar
JustForFun
thanks...got to pull the trigger on this item next week.
To Engine choice
