Rear diffuser photos
Old Feb 8, 2006 | 12:03 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Rear diffuser photos
I was asked to share a few photos of my diffuser. I finally took the time to get a few good (at least 2 are ok) pictures so here they are.
It is constructed of foam core and carbon fiber and is attached with studs using existing holes in the frame. The two forward holes are the front spare tire holder locations. I still don't have any test data. I'll get to that someday.
Old Feb 8, 2006 | 12:46 PM
TPIShark's Avatar
TPIShark
Car has a nice stance. What rims asre those, and tire size ?
Thanks.
Old Feb 8, 2006 | 02:15 PM
burners's Avatar
burners
Cruise-In V Veteran
Thanks, the wheels are Bassett racing wheels and they are their IMCA 5 spoke 15x8. Front tires are 50 series 245s and the rears are 50 series 295s. I must admit that the front ride height in the photos is a bit misleading. That is running on the bump stop. I usually have 3/4 to 1" off the stop.
Old Feb 8, 2006 | 03:23 PM
CrossedFlags77's Avatar
CrossedFlags77
How did you block off the front of the diffuser to keep air from getting trapped in above the diffuser and acting like a huge sail?
Old Feb 8, 2006 | 03:58 PM
Star79's Avatar
Star79
Thanks Burners, I was one of the ones that asked for pics. I like it. I'm probably gonna do something similar, but more "curvy and C3-ish". I'm also guessing (like crossedflags) that the front end is filled in to avoid pulling in air?
My concept is below, I'll attempt to make it out of fiberglass over an aluminum frame, with an air exit in the middle (after I get done with 50 other projects )
Old Feb 8, 2006 | 04:44 PM
burners's Avatar
burners
Cruise-In V Veteran
Star79, I like the shape. That's cool. Another fin on the outside edges would keep the flow from venting to the side of the car. The more directed to the rear, the better the drag reduction.
The front lip is rounded to encourage flow under the diffuser but it is also very close to the rear spring. The spring acts as an extension and the air is quite turbulent in this area anyway. To really do it right I should have covers that span the gap from the frame kick-up (just behind the doors) to the spring.
Old Feb 8, 2006 | 06:03 PM
84rzv500r's Avatar
84rzv500r
I like that !!! I think I'll make one with an allloy frame and some fiberglass...
I got the frontend down tight with my prototype using 4 inch material I have some 12" material and will trim it closer....
Old Feb 8, 2006 | 08:24 PM
waterplay's Avatar
waterplay
Educate me? I like the look but what does this accomplish performance wise? I assume this was done as much for performances as esthetics. Dos it increase top end, help with top end stability or what?
Old Feb 9, 2006 | 01:24 AM
Star79's Avatar
Star79
Yeah I agree a fin closer to the outside will help (aero and looks). That's just my PhotoChopped approximation (of a Ferrari F430 diffuser), used along with your actual pics to help convince my brother that it's possible. He's my Fiberglass guy
I'm thinking either aluminum frame, or maybe balsa wood covered with 'glass, like they use on the C6 floors.
I can't wait till spring, so I can get started on some of this stuff!
Old Feb 9, 2006 | 01:38 AM
Star79's Avatar
Star79
If done properly, it will reduce drag, increase downforce and increase stability. Usually when you create downforce you increase drag (using wings, etc). Speeding up the air that flows under the car creates a low pressure area (downforce), and reducing turbulence in the "dead air" area behind the car helps stability/top end. The body of a C3 has horrible aerodynamics, so managing airflow underneath is one way of improving things.
(real engineers, please feel free to explain/correct any things that I am just making a semi-educated guess on)
Also, aero improvements aside, I think it looks cool
Old Feb 9, 2006 | 03:36 AM
comp's Avatar
comp
looks good
Old Feb 9, 2006 | 07:10 AM
enkeivette's Avatar
enkeivette
Where does your exhaust exit?
Old Feb 9, 2006 | 10:59 AM
burners's Avatar
burners
Cruise-In V Veteran
Star79, that's a pretty good explanation. The diffuser aids in transitioning the high velocity, low pressure flow under the car back to static (ambient) pressure in a more controlled, efficient way. This helps to reduce wake drag. The key is efficiency. Because it is expanding the air smoothly, there is little or no turbulence that causes drag.
torqvette, my exhaust is a split side and under car exit. I can run it either or both ways together. With the exhaust running out the back and terminating near the differential I get a "blown diffuser". The mass flow of air contributes by filling in more air behind the car, thus reducing wake drag further.
Old Feb 9, 2006 | 11:15 AM
Z-man's Avatar
Z-man
Burners - I like your setup. From a looks standpoint, I think I'd round the sharp corners to make it go with the rest of the car from a visual standpoint...
To Rear diffuser photos
