Bleeding order - remind me
Old Feb 8, 2006 | 04:14 PM
fauxrs2's Avatar
fauxrs2
Default Bleeding order - remind me
Someone remind me the proper bleeding order for the rears on our C3's.
Memory says...Rt lower - Rt Upper - Lt lower - Lt upper being the proper order of bleeding of the rear calipers... but I'm not certain thats right - its been way too bloody long since ive done this.
Old Feb 8, 2006 | 04:16 PM
Higs's Avatar
Higs
Drivers Rear inside
Drivers Rear outside
Pass Rear inside
Pass Rear outside
Pass front
Drivers front
Old Feb 8, 2006 | 04:25 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Isnt it furthest away first then get closer?
Old Feb 8, 2006 | 04:44 PM
Higs's Avatar
Higs
I just followed the manual and worked as advertised.
Old Feb 8, 2006 | 08:09 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I always do the RR outer first, RR inner, LR outer, LR inner, RF, and finally LF. It helps to tap the calipers with a hammer to shake loose any sticking air bubbles.....
Old Feb 8, 2006 | 08:58 PM
SteveG75's Avatar
SteveG75
Service manual states:
LR inner
LR outer
RR inner
RR outer
LF
RF
Good enough for GM, good enough for me.
Old Feb 9, 2006 | 06:14 AM
kb2fzq's Avatar
kb2fzq
Originally Posted by Higs
Drivers Rear inside
Pass Rear inside
Pass Rear outside
Pass front
Drivers front
Old Feb 9, 2006 | 08:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I've always done Farthest First without problems.
Right Rear Inner
Right Rear Outer
Left Rear Inner
Left Rear Outer
Right Front
Left Front
Old Feb 9, 2006 | 10:26 AM
fauxrs2's Avatar
fauxrs2
THX all
Old Feb 9, 2006 | 11:03 AM
Z-man's Avatar
Z-man
I was always tought that the proper bleeding order was:
- right knuckles
- left forearm
- back of head
- wallet
Old Feb 9, 2006 | 01:17 PM
Tom454's Avatar
Tom454
I did an experiment on this a few years ago for the benefit of the Forum. As it turned out, it didn't matter which order they were bled... the result was the same even if they were bled in a random order.
I bled the system first via old school (farthest to closest), and then opened it up, drained it, and re-bled in an opposite, and then a random pattern... absolutely no difference in the final product.
I used gravity & pedal... coffee cup, wrench, & piece of hose.
Apparently, the important thing is to fully understand the mechanics/hydraulics of the system and to use whatever bleeding method/equipment you choose correctly.
Old Feb 9, 2006 | 01:26 PM
NC C3's Avatar
NC C3
You have way too much time on your hands.....
Old Feb 9, 2006 | 01:54 PM
ImBatman's Avatar
ImBatman
I am doing this now and have a similar question that is related to this. You refer to Left Outer, Left Inner, Right Outer, Right Inner for the rears. My brake calipers have both bleeders on the same half of the caliper one on the upper side one on the lower. Since I bought these from Advance I wouldn't doubt if this is wrong. Am I supposed to have one bleeder on one half and one on the other?
Old Feb 9, 2006 | 04:16 PM
Higs's Avatar
Higs
Should have all three.
Old Feb 9, 2006 | 04:20 PM
Tom454's Avatar
Tom454
Ha. (LOL)
This "experiment" was only one small part... I also tested the "brake switch" to see if it would stop the car when there was a severe line failure... I rigged up a special MC cap to accept fluid feed back from a front caliper line & drove the car... almost hit my garage door. Doesn't work all that well, but it does stop the car unless all of the fluid spurts out on the ground instead of back into the MC as I had it rigged.
I do these experiments generally to answer debates.
It's a dirty job, but somebody has to do it.
This weekend I'm testing the "roller tip rocker" theory.... do they rotate, or don't they?
Any bets?
To Bleeding order - remind me
