OK - So I thought a new 4 core brass/copper radiator with a nice new fan shroud, thermostat and water pump should keep everything cool. WRONG! My temp gauge is reading up to 240 degrees. What is the best way to go without going overboard? Is a 2 core aluminum radiator going to be that much better? Do I need to add electric fans? Will a high volume water pump make a difference? Or is it "D" all of the above?
Check your timing and make sure you have your vacuum advance hooked up and operational (running off manifold vacuum). Retarded timing or inoperable vacuum advance will run the temp right up there. With the vacuum advance hooked up, you should see timing at idle of about 32-34 degrees, and this will give you the coolest running engine possible.
You really need to see what you REALLY have in terms of heat. The best investment is getting one of those little lazer temp thingys, a pyrometer or something. They are only about $70. Then move forward. I ended up with a new high flow pump, Alum rad from Dewitts, etc, etc. I spent alot of time and $ on the whole affair. Its not as easy as one might think. Make sure that ALL of your seals are in place run a 20/80 mix and maybe throw some water wetter in too.
I got mine from DocRebuild, but there are other vendors that have them specific to your 'vette. The seals force the air through the radiator and does not allow the air to go around it. Good Luck!
Don't want to hijack this thread, but I have been chasing cooling problems also. How can I check the vacuum advance?
When does it get this hot??? City? Highway? Idle? If its while driving do you have the factory front spoiler??? The spoiler is crucial....its not just for looks...it directs the air up to the rad.
Electrical fans are a nice way to go, they work in traffic
Make sure Mechanical fan and clutch are working correctly
Make Sure Guage is reading correctly, Pyrometer as mentioned above is a good way to go, handy for all kind of stuff
Those are the basics, cover those bases and see where you are then
I am going to go with Aluminum Rad and electric fans with a soft start kit, the rad in my car is a 2 row brass and copper, not good enough for south florida traffic. Should keep it nice n cool even with air on in traffic.
Check the fan clutch. Double check that the thermostat is sitting in the correct direction to the radiator. Last thing, my vette ran at 220 all the time I added 40 below radiator treatment now I run at 200 even all year round.
The gauges are crap too....
Good luck
carbster
I'd say, find out what the REAL coolant temp is, not judging from the gauge...even if you get a turkey thermometer, take off the rad cap and put the thermometer in..should be close......you're in N.J....not Tampa...this time of year, you should run very cool, even if your seals are bad or gone...mine does in upstate N.Y., about 190 and the 240 temp...it stays there while driving or while sitting idling or always? I'll agree with the spoiler theory, but mostly the timing theory if the coolant is actually that high..
I'll bet your not running 240! All the temp sending units sold at auto parts store are wrong for the gauges and when they go over 180, the reading goes nuts. 5 over reads 15, 10 over reads 30, and so on. As recommended here, buy, steal, or borrow an IR gun. Confirm the reading before doing anything. If the sending unit is off, find the old GM one or buy a new one from lectric limited, they claim to work correctly.
The Vaccum can is easy to check. Hook up a timing light and do the timing as usual, with the vacuum hose plugged. Set the timing per the specs and lock down the distributor. Then, when you re-connect the hose to the vaccum can, it should jump another 12-15 degrees advanced. If not, the diapham is broke and it isn't working. The symptoms of a dead vacuum can are over heating at idle and running cool at high speeds.
Thanks for the information! I have ordered a radiator/shroud seal kit from DocRebuild, and found a new 16" 2500 cfm electric fan online (for under $50.00). Between the two, and checking the timing (mine is ported at the carburetor, does that make a difference?) I hope to get this issue under control. My overheating problem occurs at highway speeds only. I am turning rather high rpm's due to the 3:73 rear and the 1:1 5th gear in the Richmond trans. Off the line and for the short run the car is awesome (just ask the guy in the pro lincoln coupe!) but on the highway it leaves something to be desired. A change to a 3:08 rear is in the very near future, hopefully that will help with the heat as well. All of your feedback is greatly appreciated. Save the Wave!
aluminum 2 row radiator will beat the four row jobs..
4 quarter inch rows equal 1 inch in cooling capacity. two 1 inch rows equal 2 inches in cooling capacity....be cool
but at speed/high rpm you gotta keep the coolant in the radiator to cool it...sometimes high flow pumps and thermostats will kill you at 3000 rpm over a 20 minute time period, ie: cruise speed.
The seals make a big difference. Dr. Rebuild is the place to go for those.
