Vacuum lines
Old Aug 9, 2001 | 12:51 AM
jonny4523's Avatar
jonny4523
St. Jude Donor '05-'08
Default Vacuum lines
Can somebody post some pics of their carb. showing clearly where all of the vacuum lines go? Mine does not have smog equipment so if yours doesnt either, it would help alot. Thanks in advance.
Old Aug 9, 2001 | 01:05 AM
kenko74's Avatar
kenko74
Default Re: Vacuum lines (jonny4523)
I rebuilt my upper end and replace all my hoses. The pictures on my website may help you a little. Ignore the text, as I haven't yert worked on that. On the pass side, The hoses up front go into/out of the TCS solenoid (hard to see). On the pass side, the hose leaving on the side goes down to the vapor cannister.
http://corvetteforum.net/c3/kenko74/
Old Aug 9, 2001 | 01:20 AM
Gerry's Avatar
Gerry
Try looking under the Tech Tips. Someone posted a picture of the front Q-jet connectors there. But for your reference:
On the back, the angled port next to the brake booster goes to the air cleaner.
On the front...
drivers side low is the vacuum advance
Middle low is the PCV valve
Middle high goes to the vapor canister
passenger side low goes to the EGR
passenger side high goes to the AIR pump diverter.
To Vacuum lines
