need help with new supercharger
http://www.dyersblowers.com/
871 is big, you'll probably need high-strength, lower compression pistons, a blower-grind cam & a real good radiator ... dunno if your 69 dist will fit w/871 ... 671 probably a plenty for street 454.
I am running a 6-71 GMC blower, on top of a Weiand intake. Custom idler pulley support.
With the 2" belt, I have about 1 1/4" of clearance from the front of the belt to the back of the radiator support. It's close, but not so close as to be scary. Alternator hooks up with no alignment issues, haven't hooked up the PS pump yet, but it looks like it'll be fine, too...
I installed a Mallory Hy-fire distributor, have plenty of clearance (fitting the control box into the engine compartment was a chore, though
).I'm curious- why run an 8-71 blower?
Unless your engine is seriously built to handle the monster flow that an 8-71 can pump in, a 6-71 will be more than sufficient, and give you a bit more room to work with, in the engine compartment....
